I haven't done this in about ten years since high school. Just got a setup and wanna practice some. How do these welds look and what is causing all the yellowish coloring around the welds??? Thanks Matt. Sent from my iPhone using Tapatalk
Reply:Galvanized metal?Sent from my SPH-M830 using Tapatalk
Reply:The only thing more important than a welding machine(or torches) to perform a weld is the grinder and consumables used to prepare the steel.Your technique looks great.Clean up.UmmmIs someone going to kick yer asz over putting that on the granite ?Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:That was just steel from tractor supply I will try to clean it tonight and give it another go. It didn't hurt the granite lol. Sent from my iPhone using Tapatalk
Reply:Yellow powdery coating is usually a sign that the piece was zinc coated. Zinc and welding don't play well together. Zinc gives off toxic fumes when heated like this.I'd either get some non zinc coated material to work on, or sand/grind the piece really well to remove the zinc coating 1st..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thank you I didn't no that. Now I'm glad I took the time to rig up a fan to extract the fumes. I have some other metal I'll try tonight. Sent from my iPhone using Tapatalk |
