Ar/He Mixes...yay or nay ??
发表于 2021-8-31 22:30:38 | 显示全部楼层 |阅读模式
I am looking at getting some gas to practice my TIG skills. I noticed that there are various Ar/He mixes available on top of just Ar. Quoting the sales brochure there are apparently quite a few benefits to Ar/He mixes like increased head transmitted to the weld pool, increased wetting, travel speed and optimized shape of penetration. Is anyone using Ar/He over here ? I am looking at general carbon steel, a bit of ss and maybe al when I get a chance, all thin stuff, mostly gauge thickness'. Should I bother with Ar/He or should I just get Ar ?
Reply:Just use straight argon. Adding Helium can help in some cases where your machine needs just a bit more power than it has for a specific job. However it's not going to turn a 165 amp class machine into a 250 amp class unit. You might gain 15-20 amps worth of output.If all you are doing is thin stuff adding helium to the mix will just increase your cost..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Like DSW said, you need a particular reason so use helium. It is typically used to aid the welding of heavy alum. Argon will be just fine for steel.Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
GMT+8, 2025-12-31 15:10 , Processed in 0.095709 second(s), 18 queries .
