getting back to it.
发表于 2021-8-31 22:30:37 | 显示全部楼层 |阅读模式
So I have and been working as a machinist for the last few years and only did TIG  at home on my own projects and when someone messed up a part in the shop. but I just started two days ago as a welder again. 95 percent of the job is aluminum TIG welding pipe. Pretty much building tuna towers and similar. Anodized and non anodized. I am having trouble spacing my beads correctly to get them clean and look like they use to. Seems like welding truly is a perishable skill. I didn't find and decent videos to hopefully refresh my skill. Anyone have a link to one or have any tips for me?Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
Reply:Welding-tv.com and weldingtipsandtricks.com Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:If your welder has pulse set it to around 1pps it will help give you a cadence to follow....just dab at the peak Sent from my XT1080 using TapatalkAWS 17.1, D1.1 and ASME IX (GTAW)Miller Syncrowave 350LX, Maxstar 150sth, Maxstar 200DX and  Millermatic 252 w/ Spoolmatic 30aMiller buzz box with Lincolin TombstoneThermal Dynamics Cutmaster 38
Reply:Pulse isn't really ideal for what I am doing. There are a lot of miter joints and funny angles where your constantly repositioning to get the right arc length and angle. 1.9" o.d  and smaller aluminum tube.I have been manually pulsing right now. Instead of just keeping a relatively steady and amperage. Would it be better to just keep a steady amperage and move along adding filler? Or is pulsing by easing off the foot pedal, moving a half of bead, easing back in to it, and adding a slight amount of filler the way to go?Lincoln Square Wave 175 TIGLincoln 110v flux core welder (my 1st)Clarke 180EN MIG
GMT+8, 2025-12-31 15:10 , Processed in 0.074271 second(s), 18 queries .
