Drill bit the blaster rung off his drill steel in. my new concrete demo hammer. Not sure if the handle will last but it's what I had lying around. Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Please video the first time you use it.My name's not Jim....
Reply:Solid steel handle???You better have some real beef behind that hammer...Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Yep, video camera, steel handle, eye protection optional. Now hold my beer and watch this!.................Cool hammer though. $399.95 to a zombie warriorArcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:I have a sixteen pounder that I installed a 1 1/4" steel handle on probably twenty years ago. I named her "mamacita". She's done a ton of work over the years.However, on yours, did you bore a hole for the handle to pass into before you welded it up?life is good
Reply:Is the head or tips hardened steel, I'd think it would shoot shrapnel off after a good hit on solid concrete?
Reply:Can we say..VIBRATION....lol..use some padded gloves when swinging that thing...Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:up here they call a hammer like that a monday. swing that a couple few times and you feel like it's monday.i.u.o.e. # 15queens, ny and sunny fla
Reply:Yeah I wish I could've bored a hole in before welding but it's some pretty hard stuff. And I don't have the equipment to handle that task. As for it sending shrapnel flying it is a drill bit made for a very large hammer drill (300 lbs of so)that was boring blue granite. As for vibration yes! and lots of it I plan on padding the handle somehow. The main use for it will be breaking concrete cookies left by a pump truck. I'm not sure of the weight but I will find out. I think I will name it Monday thanks docwelder.Thermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:Yup 17 lbs of sore back n shoulders lol. Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter
Reply:I was always hard on splitting maul handles as a kid... My Dad got tired of replacing them so he welded in a piece of pipe for a handle. It hurt sooo goood!"The beauty of the Second Amendment is that it will not be needed until they try to take it." - Thomas Jefferson If the Lights are a Flashin', STAY OFF the tracks!!! It might be me at the Throttle...
Reply:Yeah! No way I could swing something like that at my current age and shape.When I was in my late 20s, I sold firewood as a side line. Too poor and cheap to afford a log splitter then, so I came up with an idea to fabricate me a splitting maul hammer.I made the wedge shaped striking head out of 5 pieces of 5/16" thick steel plate so it was hollow inside.I welded it up so that it was 2 Vee shaped pieces welded to 2 rectangle pieces so it had the wedge shape. The back side of the striking head formed a square opening, so I welded a square plate of steel to close that off, did that as the last thing.I had a piece of bulldozer track pad and cut a "knife edge" out of that and welded it to the pointy end of the wedge.I had some kind of 1" shaft out of some factory machine that I welded on for the handle.I filled the cavity 3/4 full of 1" pieces of lead tire weights before I welded the square end cap on to close up the cavity.The idea behind the pieces of wheel weights was that it should make it act like a dead blow hammer, and add a bit of mass to the head.It was a bad boy, but it also gave the Monday feeling.I never could decide if the lead shot enhanced anything about how it worked, but it worked..........the hell out of you.
Reply:Are those carbide buttons in/on the end there? If so those won't hold up real well if you ever manage to get a good swing on it. I had a 16 pounder years ago. Loaned it to a guy busting up a sidewalk and told him to dump it in the gulley with his last load. I had found it years earlier out in the brush at an old old subdivision site. After a few swings I found out why it was off in the brush."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:When I get around to using it I will let you know how it goes. Sent from my iPhone using TapatalkThermal arc 211iCk flex-loc 150 & 130Clamps, saws & grindersHarbor freight 80 amp inverter |
