Didn't Break In Half
发表于 2021-8-31 22:30:29 | 显示全部楼层 |阅读模式
Pulled a load of hay out of Bixby today.  I wanted to see how it would behave when loaded to the design limit (7000gvw)I scaled it at a local gravel pit, and the axle weight on the trailer was 6700#.  Pretty darn close to it's rated capacity.I then dropped the jack leg, and raised the tongue a bit off the ball with the tongue scale under the pad.  This gives a real close approximation of the actual weight resting on the ball.6700 axle weight + 850 tongue weight = 7550# GVWPayload figures out to 7550 - 2400 (empty weight)= 5150#This points out the importance of "transfer weight".  The truck carries part of the load on the hitch, otherwise the trailer would be overloaded.It also points out the variance in hay bale weights.  The guys that sold these to me swore that they were 1000lbs.  I've been around this stuff long enough to know that it's rare that a 4x5 bale weighs 1000lbs.  Otherwise I wouldn't have loaded 6 bales on the trailerSo anyhoooo............nothing dropped off, nothing cracked, and the hitch on the truck (a small point of controversy when I built it) seems to have survived"Any day above ground is a good day"http://www.farmersamm.com/
Reply:PASS!!...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Sam, that pup is looking sweet. I see she is checking your math!Miller MM 211Miller 375 XtremeO/A
Reply:Awesome. Nice to see proper straps on the bales. Good work on the trailer.
Reply:Tell us about that scale, what is it?Using hydraulic pressure ?
Reply:i wanna know about your truck!bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Looks good.  But, I do want to point out to others...  Now, this is going to depend on how your state runs things but "here" in PA if your trailer is not combination registered to your truck, you cannot go over the GVWR of the trailer and of course any trailer over 10K must be a combo deal anyways.  But this means on those light trailers, if it is 7000 lbs gvwr, that means if they unhook it from the truck it, sitting on the jack and tires, it cannot be over 7000.   You are allowed the weight transfer to vehicle if registered as a combo though and are limited by overall combo registration and axle ratings.   So, "here" that is not a legal setup without a combo registration as the trailer is over it's GVWR.  That said, I would roll with it anyways.
Reply:No doubt some states have weight laws that just leave you wondering or scratching your head and I'd love to see that "non-combo" trailer pull itself down the road. Really nice job Samm. MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Glad all went well for you Samm,Not for a moment did any of us have any doubts,Superb job and useful too, Another one to be proud of.Lincoln SP-170 MigHypertherm powermax 45Lorch T220 AC/DC TigButters FM 215 synergic MigKemppi 180 adaptive mig RULES ARE FOR THE OBEDIENCE OF FOOLS AND THE  GUIDANCE OF WISE MEN.
Reply:Originally Posted by 12345678910Tell us about that scale, what is it?Using hydraulic pressure ?
Reply:A REAL farmer would have stacked another row on top of those bales.. Just sayin'. Glad to see your work pay off with a safe load Samm Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:That pressue guage sounds like a great idea for a hydraulic jack. It would let most people know how much they are lifting / overloading. I wonder why they arent in all jacks or at least set up for it as an option.Miller thunderbolt 250Decastar 135ERecovering tool-o-holic ESAB OAI have been interested or involved in Electrical, Fire Alarm, Auto, Marine, Welding, Electronics ETC to name a just a few. So YES you can own too many tools.
Reply:I've hauled 4 tons of green live oak logs with 3/4 ton chevy pickup the suspension was beefed up using 2 1/2 ton air bellows. The dry weight of truck was 4,800 lbs and GVWR 7,500 lbs.
Reply:Originally Posted by res0r9lmI've hauled 4 tons of green live oak logs with 3/4 ton chevy pickup the suspension was beefed up using 2 1/2 ton air bellows. The dry weight of truck was 4,800 lbs and GVWR 7,500 lbs.
Reply:Real good job and cute little pup.
Reply:Nice work, for sure.Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Sam you could have fit one more bale on the bed of the truck and two more on top of the trailer... LOL That's how they do it around here. Glad to see proper straps and some sort of "legal" load. Trailer is awesome by the way.Quality work is never Cheap, and Cheap work is never Quality!!If it's broke, and you're not, we can fix it!!  Lincoln Idealarc sp200Century 230amp ac/dcSmith O/A TorchesHuth Hyd. Pipe Benderother misc "cool" tools
GMT+8, 2025-12-31 15:08 , Processed in 0.095938 second(s), 18 queries .
