pipe stand build
发表于 2021-8-31 22:30:28 | 显示全部楼层 |阅读模式
Here is my pipe standing I building here is what I have so far what size pipe should I use for the stand?Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:Those are real handy. I have a couple with rollers on top. I think mine are around 1 1/4" with 1" inside slider. I was lucky enough to have some seamless tube so I made them adjustable with some homemade wing nuts. Just depends on what you want to use them for as far as size I guess.
Reply:Originally Posted by PipelinerThose are real handy. I have a couple with rollers on top. I think mine are around 1 1/4" with 1" inside slider. I was lucky enough to have some seamless tube so I made them adjustable with some homemade wing nuts. Just depends on what you want to use them for as far as size I guess.
Reply:Like the roller on this. I think thats what he is talking about.http://www.northerntool.com/shop/too...FUMF7AodtUAAzQGravelThe difference between theory and practice is that in theory there is no difference.
Reply:I don't have a picture with me but the roller like Gravel linked is what I'm using minus the roller balls. Just set the roller down in the uprights so long pieces don't walk off the sides.
Reply:If I don't do that can I do it any other way? To adjust the height ?Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:Use some acme rod or just some all thread. Or square tubing but you will still have to deal with the seam unless you get seamless.
Reply:alright ill take a look it to that.Lincoln 140 Pak MIG Everlast powerarc 140 STLincoln Tombstone
Reply:Here are some I've built, bought, and modified. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I made mine for school a little different.  I wanted one height for the saw and one to extend the table.  It is limited to those two heights, but it also works great as material handlers.  I could always add additional fixed heights to the other sides if needed.The limitation is it is not adjustable, but it sure is solid.  I could slot the rails, but I wanted something that the students would not be able to lose any parts, or screw up the adjustments.Last edited by Crabo; 05-19-2014 at 09:01 AM.
GMT+8, 2025-12-31 16:55 , Processed in 0.110057 second(s), 18 queries .
