Welding chromoly tube connectors to mild steel tubes
发表于 2021-8-31 22:30:28 | 显示全部楼层 |阅读模式
I was thinking of using these interlocking tube connectors to attach my engine cage to the frameThe connectors are chromoly and the cage is mild steel, is it ok to just mig that like normal?
Reply:Do you know what kind of chromoly?depending oon the carbon content, preheating might be necessary.Mig with "normal" wire will most likely do fine (depending on the grade of chromoly).
Reply:Originally Posted by kingneroDo you know what kind of chromoly?depending oon the carbon content, preheating might be necessary.Mig with "normal" wire will most likely do fine (depending on the grade of chromoly).
Reply:4130 over 1/8" technically requires pre-heat so, yeah the other ones might give you less trouble. Got TIG?SqWave 200Millermatic 190Airco 200 ACHypertherm PM45Boice-Crane Band SawVictor O/A
Reply:Originally Posted by Brazin4130 over 1/8" technically requires pre-heat so, yeah the other ones might give you less trouble. Got TIG?
Reply:Mig welding will be fine.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
GMT+8, 2025-12-31 15:09 , Processed in 0.102830 second(s), 18 queries .
