What is a SA200 parked in the weeds worth ?
发表于 2021-8-31 22:30:28 | 显示全部楼层 |阅读模式
I know that cheap "barn finds" are everyones dream, but I assume that pulling stuff out of the weeds are typically not worth cost + effort.   Does $700 seem overpriced ?http://minneapolis.craigslist.org/hn...182246980.htmlI won't have time for a project until I retire or get laid off, whichever comes first.   If I did buy something like this, I would have to prep and store it in the barn.   And if I die before I retire, then it will end up as a barn find for someone else.Century buzzbox that I learned on 40+ years ago (was Dad's)Crappy Century 110volt mig 70 amp pigeon pooper.Lincoln Idealarc TIG-300
Reply:too much, figure scrap value a few hundred, unless you can fire it up and see if it welds....then thats a different story...Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:I paid $250.00 for this one. It was way back in the black berries. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I'm with CEP and have never paid more than $220 for a unit that looked like either his or the one you're looking at which is just about total scrap value.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:If I'm buying, it's worth $200.If I'm selling, it's worth at least $1,000 since I'm selling you a world famous machine that will be completely awesome and make you weld like a rock star, the envy of all your buddies, after you fix it up. Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Just Called the guy, Shane, it's sold.  Checked for critters, added fresh fuel and it popped off and welded.  A "weldor" picked it up.  Maybe it was Bead-boy?Everlast PowerPro 256, Everlast W300 Cooler, Everlast Cart 250Millermatic 211, Spoolgun 100, Miller HD CartJackson W60 Truesight Digital Auto Darkening, Victor 315 Torch sitting on a Harper 830-86 cart
GMT+8, 2025-12-31 15:17 , Processed in 0.213102 second(s), 18 queries .
