Transporting a Miller 252 on its side?!?
发表于 2021-8-31 22:30:26 | 显示全部楼层 |阅读模式
I have an eye on a Miller 252, but don't have my truck at the house.  So if I go pick it up I'll have to put it in my car.  Would there be a problem if I picked the welder up and transported it on its side?Thanks,Bryan
Reply:Don't see any reason why not, just remove any wire inside it and the gun first, and use common sense.I once put an MM 200 in the trunk of my Chevy Caviler and it sort of laid on its side. No issues.Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Good to hear, thanks.  I was concerned about knocking a board or transformer loose and tearing something up inside the box.  Good call on removing the wire too.  I can see how being shaken around with some weight could mess up the drive.Bryan
Reply:I see a problem, they weight a touch over 200 pounds.I see someone hurting their back getting it into, or out of, a trunk.Plus,the dimensions will make it hard to swing over and stuff into the trunk.Other than that - I say good to go. Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Call a friend who owns a truck and buy him a case of beer to help.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Rent a truckMagazines have issues, everything else has problems
Reply:Just be careful that you let it sit upright for at least 30 minutes afterward to let all the electrons settle back down to the horizontal position.
Reply:Or a mini van.  12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:I've always thought mini-vans were pretty practical for this kind of stuff.Always been fortunate enough to own a truck, but a mini-van would sure work.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:4x8's fit in the mini van just like a truck box!12v battery, jumper cables, and a 6013.I only have a facebook page. https://www.facebook.com/pages/VPT/244788508917829
Reply:Originally Posted by VPTOr a mini van.
Reply:Originally Posted by walkerJust be careful that you let it sit upright for at least 30 minutes afterward to let all the electrons settle back down to the horizontal position.
Reply:As long as you dont try to shove a 330cf cylinder in there also you should be fineMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
Reply:Originally Posted by farmshopAs long as you dont try to shove a 330cf cylinder in there also you should be fine
GMT+8, 2025-12-31 15:10 , Processed in 0.115145 second(s), 18 queries .
