Canadian Forces hiring Hull Technicians.
发表于 2021-8-31 22:30:26 | 显示全部楼层 |阅读模式
Hi guys.Anyone have any first hand experience about the Canadian Navy hull tech trade?The position is open apparently.I'm thinking of going tomorrow to have a kick at the can.I doubt I'll get in because of criminal record and essentially being blind as a bat.
Reply:Originally Posted by Oleg StefanivHi guys.Anyone have any first hand experience about the Canadian Navy hull tech trade?The position is open apparently.I'm thinking of going tomorrow to have a kick at the can.I doubt I'll get in because of criminal record and essentially being blind as a bat.
Reply:many people have criminal records and are doing just fine. being blind may be a bigger handicap to a welder.i.u.o.e. # 15queens, ny and sunny fla
Reply:Good luck, hope you get in."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:The hulltech trade is a combination welder, woodworker, and Plummer all rolled into one.I would suspect that most trades are open in the forces, the conviction may be a showstopper but you'll need to investigate.Sent from my iPhone using TapatalkBriggs weldnpower 225/210/cvLn-25 suitcaseMillermatic 130
GMT+8, 2025-12-31 15:09 , Processed in 0.122270 second(s), 18 queries .
