Good ac rod for vertical
发表于 2021-8-31 22:30:22 | 显示全部楼层 |阅读模式
Running a Lincoln tombstone ac225, I've always used 6013 or 6011 but I'm wondering if there is something that I could run that would improve my vertical welding. I can weld really well in the horizontal position but I absolutely suck welding vertically, both traveling up and down and left to right. Was wondering if there is an "easier" rod for this. Btw I'm just a halfa$$ed hobby/farm welder that learned in "ag" class at 13 years old. :-)Sent from my iPhone using Tapatalk
Reply:Just post a practice vertical weld and these guys can help you dial it in.Both those rods are fine - it takes many many hours to get it right every time Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I'd crank your 5/32 6011 up, and run them downhill.Its a far cry better than cursed 6013 uphill.~JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:A lot of guys can do a fair job flat and horizontal because they can get away with running timing patterns. That does NOT work in vertical. To do vertical well you 1st must learn to read the puddle and manipulate it. As Dave said, post up picts with settings and material thickness so we can see you issues, and we'll give you some suggestions on how to improve. My guess is you haven't learned to read the puddle yet.As far as rods, there's no "magic" rod that will make a poor welder do vertical well. I like how 7014 runs over say 6013 or 6011, but any of the three will work just fine. 7018 is another option, but not all AC machines will run it well. If it will run nice, I'd put it right up there with 7014 as one of my favorite rods to run in vertical..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Originally Posted by 19wayfarer50Btw I'm just a halfa$$ed hobby/farm welder that learned in "ag" class at 13 years old. :-)
Reply:CEP, you hotdoggin' again Hilco Brown running downhill. Runs just like 6011 but a smoother(prettier) bead.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:As usual, DSW is right on. There is no magic rod that can make you put in a nice vertical up stick weld. You use the same rods to weld vertical up as you do flat (except for a 7024 type rod). You just haven't developed the skills to weld vertical up yet. It is nothing like welding flat with stick. It isn't the rods fault.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:I'm telling you man, crank your 5/32 6011 up to 135amps and run them downhill....Its real easy and will be really strong if done right.~JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:Try 7014 downhill keep a tight arc, literally dragging it downhill.   Don't let the slag fool you.  The slag will run and drip but the weld underneath will be flat and smooth like cream cheese spread on a bagel.  You might have to play with your speed, but after your 3rd electrode max, you'll figure it out and see a beautiful weld appear when chipping the slag.  I'd almost guarantee that the slag will peal off by itself. 7014 will be your new favorite electrode and you should get that instant gratifying feeling out of your system. Then after that, go practice and take the advice of what the others said withe the other electrodes.Lincoln Power Mig 216Lincoln AC/DC-225/125Miller  625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita  Baileigh NRA Life Member
GMT+8, 2025-12-31 15:10 , Processed in 0.071699 second(s), 18 queries .
