Will a 8000 watt 10000 peak generator satisfy my welding needs?
Reply:And whats that look like?A harbor freight 110 mig and 4 inch grinder, yes.A 250 amp AC arc welder that you plan to use any where near 200 amps, no, not even close.Last edited by mad welder 4; 04-01-2014 at 10:55 AM.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:Need waaaay more info for anyone to attempt to answer your question.Basically, it's what you plan/need to weld will dictate what you need for a welder which (based on it's power requirements) will dictate what you need for a generator to power it. Attempting to select the generator first is putting the cart before the horse.Perhaps an engine drive welder/generator will meet your welding needs once you determine them.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:depends on the welder. 8000 watts at 230 volts is 35 amps. You can run a HH210 MVP on 24 amps. But the Hobart Stickmate needs 47 amps at full load.Miller Multimatic 255
Reply:Louie while that may be true based on numbers, in reality things don't always work so neatly.Lincoln lists about 50 amps 230v required to run an AC 225 transformer stick machine off line power. So based on that you'd think you could go max power off an 11.5 KW gen set. Less since many guys run these of 30 amp dryer circuits at reduced power. However Lincoln recommends at least a 15 KW genny to run those. I know several guys who have tried to run these off mid size gensets that the math says should work. In reality they won't weld even though the math says they should be getting enough power.Issue is you have several factors all ganging up at once when trying to power heavy draw equipment off generators. You have inefficiency at both ends, as well as that you need the extra output so the genny can throttle up when it senses a load. Add things like voltage drop either due to Rpm's not correct, or loss in lines, and things just don't work out in the real world like the math says it should..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Fair enough, power correction factors and whatnot. what I don't get is these small generator welders that say they do 225 amps but are only rated 4K watts as a generator??Miller Multimatic 255
Reply:Originally Posted by bitterfitterWill a 8000 watt 10000 peak generator satisfy my welding needs?
Reply:Originally Posted by Louie1961Fair enough, power correction factors and whatnot. what I don't get is these small generator welders that say they do 225 amps but are only rated 4K watts as a generator??
Reply:And thats why welding generators are awsome.The power grid can give you almost unlimited starting current, always at 60hz and has no problem over coming a horrible power factor.Smaller 120 and 240 volt generators cant do any of ^ that ^.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:You can run a HH210 MVP on 24 amps. But the Hobart Stickmate needs 47 amps at full load.
Reply:Thanks guys I will def be looking for a welder gen.
Reply:Originally Posted by bitterfitterThanks guys I will def be looking for a welder gen.
Reply:The only way a regulat generator might make sense is if you could get a 12kw or bigger for really cheap.Even then you might want to still sell it to fund a welding generator machine.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder |
