Fluxcore
发表于 2021-8-31 22:30:21 | 显示全部楼层 |阅读模式
Hey all I am building a trailer out of 3/16 angle and I am using  fluxcore lincoln nr211 mp .045 diameter, I tried recommended settings and can't seem to get good weld or penetration I also. Have porosity was using 19v 115 wfs please help
Reply:Is the material galvanized? Can you post a picture that'll help a lotSent from my XT1080 using TapatalkAWS 17.1, D1.1 and ASME IX (GTAW)Miller Syncrowave 350LX, Maxstar 150sth, Maxstar 200DX and  Millermatic 252 w/ Spoolmatic 30aMiller buzz box with Lincolin TombstoneThermal Dynamics Cutmaster 38
Reply:Regular steel & I don't have picture
Reply:Originally Posted by FlyingJRegular steel & I don't have picture
Reply:On Lincoln's chart it lowers volts and wfs as wire gets bigger but with solid wire as it gets bigger you use more volts
Reply:I do a lot of solid wire mig and stick bt first time I have to use fluxcore
Reply:Originally Posted by FlyingJI do a lot of solid wire mig and stick bt first time I have to use fluxcore
Reply:When you say building a trailer, you mean a yard cart for behind the lawn mower right?Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Helping friend with broken welds on landscaping trailer
Reply:You could probably lower the voltage a couple easy."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:I'm sure you have the product info but here's a little snip right out of one of their brochures. Attached Images"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:I can't even begin to help without a picture. Most of the time I have to be able to touch something to really see it. This was that 30-year old rusty .068” NR-211MP. First pass, and the settings. If you can post a picture, I might be able to help. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by SandyI'm sure you have the product info but here's a little snip right out of one of their brochures.
Reply:I'm new to this welding game. But in my opinion, these charts are all fine and dandy. To me they are just suggestions! There are so many variables, I can't possibly wrap my mind around all of them. So for me, I adjust the welder, and wire feeder to suit me for what I'm trying to do. In short, I do what ever the puddle requires. I don't sweat the small stuff.  Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by 4956Attached Images Attached Images   Looking at that chart there's some thing that has me confused....The second line in the .035 block where it gives a WFS of 70 and Volts of 15 it gives the approximate current as 60 Amps.But then in the first line in the .045 block where it gives the same WFS and Volts (70 & 15) it gives the approximate current as 120 Amps.How can that be?   Wouldn't the same WFS and Volts have the same approximate current value no matter which size wire was being run?
Reply:DOES ANYBODY EVER TAKE THE TIME TO READ PRODUCT MANUALS/DESCRIPTIONS????!!!NR-211MP is not formulated for seismic welding.  It's not Charpy rated.  IN OTHER WORDS.....................IT MAKES NON DUCTILE BRITTLE WELDSIt ain't the stuff to use for anything subject to vibration or twisting, and will not survive high impact loads.If you're going to use wire, use Dual Shield."Any day above ground is a good day"http://www.farmersamm.com/
Reply:First it's "building" a trailer, then "fixing" some broken welds.  Which is it?????Fixing.........maybe.  Building..........no"Any day above ground is a good day"http://www.farmersamm.com/
Reply:With FCAW, you should drag,to avoid slag in the weld. With MIG, you push for better penetration. Im just a hobby guy but thats what I read in a LINCOLN Electric book somewhere.
Reply:Originally Posted by InsanerideWith FCAW, you should drag,to avoid slag in the weld. With MIG, you push for better penetration. Im just a hobby guy but thats what I read in a LINCOLN Electric book somewhere.
Reply:Well then, I guess thats debatable. Im a LINCOLN man so I will stick with push for better penetration.BTW, Lanse did an experiment testing push vs. pull penetration. Can you guess what delivered better penetration?  Hint: Lincoln is correct.Beware of false information.Last edited by Insaneride; 04-04-2014 at 10:04 AM.Reason: False information
Reply:Some of the self shielded wires can be hard to get a trend on as far as wire size/feed/amps. With the solid wires there are some trends ans far as feed speed vs amps vs diameter that you can kind of get a grip on but these flux cores seem to have some anomalies that make it to where you really should take a quick look at each brand and each size of each brand before you take off running it. Or just tune to sight and sound. "The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:New Lessons in ARC WELDING   Lesson 7.10 Job A: Run stinger beads ...a. Forehand is used for heavy material (push)b. Backhand is used for lighter material (drag)This is on page 7-51
Reply:He let someone use the trailer and they broke the welds on the sides and uprights
Reply:Originally Posted by FlyingJHe let someone use the trailer and they broke the welds on the sides and uprights
Reply:Originally Posted by CEPGuess what I just came in the house from doing?Originally Posted by asdfSupervising her repair job?
Reply:I welded up a 1/4 t joint n tested with BFH it  held so before I do trailer il do a 3/16 joint bend test. Man this fluxcore is nasty smokey stuff & it sounds more like stick then mig - no buzzing just crackle like stick weld
Reply:Originally Posted by FlyingJI welded up a 1/4 t joint n tested with BFH it  held so before I do trailer il do a 3/16 joint bend test. Man this fluxcore is nasty smokey stuff & it sounds more like stick then mig - no buzzing just crackle like stick weld
Reply:Originally Posted by asdfSupervising her repair job?
Reply:I stand corrected again.  Them Miller_MIG boys know there stuf. The xplanation I got was: dragging aims the arc at the puddle and causes deeper penetration. It seems that those who could xplain it preferred to push and said it was just a matter of what worked best. It seems that deeper penetration does not necesarilly yield better welds. If it did, Im sure them Tigr's would drag instead of push.All I wanted to do was point out that FlyingJ should drag FCAW if he wasnt already doing so.Last edited by Insaneride; 04-05-2014 at 09:53 AM.Reason: Beware of blind knowledge
Reply:Anything that produces slag I try my best to drag. But as we all know sometimes you have to weld in all directions. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Thats what I thought CEP. I do have a wire feed question for you: will an LN25 work off of an INVERTEC 250s? I dont clearly understand CC CV .
Reply:Mine works perfect off my V-350-Pro.  Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by InsanerideI stand corrected again.  Them Miller_MIG boys know there stuf. The xplanation I got was: dragging aims the arc at the puddle and causes deeper penetration. It seems that those who could xplain it preferred to push and said it was just a matter of what worked best. It seems that deeper penetration does not necesarilly yield better welds. If it did, Im sure them Tigr's would drag instead of push.All I wanted to do was point out that FlyingJ should drag FCAW if he wasnt already doing so.
Reply:Self shielded flux core is run constant voltage straight polarity. On a cc/cv machine voltage is set @ the machine & remains fairly constant @ the gun depending on the size/length & condition of your cables/Quick connects etc. Amperage is determined by wire feed speed & length of stick out
Reply:So it  should look and sound  more like stick then mig ?
Reply:Originally Posted by MinnesotaDaveI'm puzzled by you extending mig reasoning and techniques to the tig process though.
Reply:Originally Posted by InsanerideWhat I dont understand is; why does an LN25 MIG work from an INVERTEC but not an SA 200 w/out CV box. I thought they were both constant current
Reply:oops wrong post Attached ImagesLast edited by M J D; 04-06-2014 at 04:28 PM.Reason: wrong postMiller xmt304,  Miller S22 p12, Miier Maxstar SD, Miller 252 w 30A, Miller super32p12, Lincoln Ranger 9, Thermal Arc 181I with spoolgun, Hypertherm 10000 ,Smith torches. Esab 161lts miniarc.
Reply:My only ? Is should it sound like mig or stick
Reply:Mig gun is in negative ground is positive
Reply:Originally Posted by FlyingJMy only ? Is should it sound like mig or stick
Reply:But it's all position ccorect?
Reply:Originally Posted by FlyingJBut it's all position ccorect?
Reply:With lincoln nr211 mp .045 How many volts and wire speed do you use for 3/16 Lincoln's chart says 15-19 it seems low to me
Reply:Pick your poison:Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I rarely use lincolns wire anymore but I do run either Hobarts T-11 or a brand called Weldcote (weldcoat?) in .045. Always run the voltages down around 16 to 18. Pretty wide sweet spot as far as the feed speed goes. If you've noticed the slag coverage on these wires is fairly light. From a slight layer to sometimes nothing more than a dust cover. Start getting the voltage and/or the voltage to feed speed ratio way out and you'll lose that slag coverage and start getting porous crappy colored beads. I generally run a fairly close electrical stick out and contact tip to work distance. Probably little closer than you should. I go for the hiss sound. It runs sweet enough tho that you can pull way back if you need to. Pretty forgiving. Lincolns is not so much so forgiving."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Originally Posted by SandyI rarely use lincolns wire anymore but I do run either Hobarts T-11 or a brand called Weldcote (weldcoat?) in .045. Always run the voltages down around 16 to 18. Pretty wide sweet spot as far as the feed speed goes. If you've noticed the slag coverage on these wires is fairly light. From a slight layer to sometimes nothing more than a dust cover. Start getting the voltage and/or the voltage to feed speed ratio way out and you'll lose that slag coverage and start getting porous crappy colored beads. I generally run a fairly close electrical stick out and contact tip to work distance. Probably little closer than you should. I go for the hiss sound. It runs sweet enough tho that you can pull way back if you need to. Pretty forgiving. Lincolns is not so much so forgiving.
Reply:Originally Posted by farmersammAnother thing I hate is when the slug of crud that builds up on the tip eventually comes off the tip while welding, and is carried by the wire into the puddle.  Drives me nuts, but it doesn't seem to affect the look of the finished bead.
Reply:Thanks all I appreciate it
GMT+8, 2025-12-31 16:57 , Processed in 0.106878 second(s), 18 queries .
