Since I can't find a thread already made, I'm ding some welding on a dump body soon. It isn't structural, and I don't have any gas and I'm not going to go buy a tank for what I'm getting paid. I'm using a 110v Lincoln. What is the best gasless wire? Anything will help, thank you!
Reply:Metal Inert GasYou're looking for Flux Core wire.It's all filthy, smokey, spattering $hit. Just buy a roll for the thicknesses of metal you're welding.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:I used to only run lincoln flux core wire. It only comes in 2 sizes that will fit that machine, 0.03 and 0.035, neither is good for sheet metal.old Miller spectrum 625 Lincoln SP-135 T, CO2+0.025 wireMiller model 250 and WP-18V torchCraftsman 100amp AC/DC and WP-17V torchCentury 115-004 HF arc stabilizerHome made 4 transformer spot welderHome made alternator welder
Reply:He should be good on the gauge steel most light weight to medium weight dump bodies are made of. I doubt the material is heavier than 11 ga tops, and is more likely 14 or 16 ga depending on who built the body and what size truck it is.With a small 110v machine, you will want .030 FC wire. The bigger wire will eat up too much power. I'd also go with the heaviest extension cord you can manage to get. 12 ga minimum, 10 ga would be better. You'll also need to run off a dedicated 20 amp outlet.I'll leave the actual wire selection to those with more time on FC wire..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:lincoln nr211mp .030
Reply:Whats the thickness? And buyer beware about flux core wire it's expensive so I would go to a welding supply and buy the house brand i.e Radnor,Pinnacle Alloy,etc or order it off E-bay.Lincoln pro core 125 14''chop saw7 inch grinder,2-4.5 inch grinders,electric die grinder.Half inch drillAnd alot of hand tools
Reply:The lincoln flux core wire at lowes and home depot is priced reasonably and runs decent I wont touch there rods though.1982 miller blue star 2E ac/dcHarbor freight flux core posVictor oa
Reply:Originally Posted by steven325The lincoln flux core wire at lowes and home depot is priced reasonably and runs decent I wont touch there rods though.
Reply:Originally Posted by ANVILThe Lincoln Fleetweld electrodes found at Hosed Despot and Blowes work just fine. Lincoln makes good chit.
Reply:Lincoln rods sold at HD and LS, are mostly cheaper seconds in the cardboard boxes.... Junk.Stick to metal boxes.As to FCAW wire,Forney makes some of the best.IMO~JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024 |
