Cutting 3" steel for Ripper
发表于 2021-8-31 22:30:19 | 显示全部楼层 |阅读模式
Had to make do with too small of a tip - all i had to use and it was on a Sunday.  Koike hand torch . Attached Images
Reply:WOW!! Ive never seen a torch like that before. Nice work, and all I can say is; I'm glad I'm not the one paying for that chunk of steel [Account Abandoned 8/8/16 Please Do Not Attempt Contact Or Expect A Reply]. See you on YouTube! -ChuckE2009
Reply:Holey Jebus!  Thats a chunk o iron!  Nice cut!Please dont mistake my enthusiasm for talent!
Reply:Originally Posted by Swamp ratHad to make do with too small of a tip. . .
Reply:travel speed looks ok, maybe alittle faster, but not much.  I would definately say your tip is too close to the metal.  You have your cutting pressure right on for the money.  If you can't move your tip up, try reducing your preheat temp.  I cut alot of thick metal at one tank shop with a victor cutting buggy.  Loved that buggy!Can you post some more pics of your torch?
Reply:Thanks guys , the cutting tip height is called being in too much hurry or ( Lazy ) to reset it correctly. This is the height that does best on thin - 3/4 " to 1' , i was in a hurry to get the machine back in a rock pile and didnt take the time to reset. But on the up-side , it gave a nice chamfer on one side that i didnt have to grind. ha haLast edited by Swamp rat; 05-08-2011 at 08:46 PM.
Reply:Finally had time to replace old tooth adaptor , now time to try it out !!!  Last two pics. show some of what it going to be ripping. Attached Images
Reply:Originally Posted by LanseWOW!! Ive never seen a torch like that before. Nice work, and all I can say is; I'm glad I'm not the one paying for that chunk of steel
Reply:It is very handy, it gets used a lot on thick plate, saves a LOT of grinding !
GMT+8, 2025-12-31 16:57 , Processed in 0.098435 second(s), 18 queries .
