lincoln weldpak hd wire ?
发表于 2021-8-31 22:30:16 | 显示全部楼层 |阅读模式
i got a lincoln weldpak hd fluxcore wire welder. i was wondering if a 10lb spool of wire will fit in it. it seems like im always using these one pound spools up soo fast. will a 10lb spool fit? THanks
Reply:I'm thinking to large, good question though. Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:Weldershane do some checking but I think you can get the small spools in 2#.I just got a wire welder and had looked around and noticed home depot had small spools and they said 1#.I swear farm + fleet -tsc and other places were 2#.This wasn't lincoln wire but you don't have to have it really.My 125 ez says it can use an 8'' spool but I would have to buy the availabe adapter.Maybe yours is that way too.pro-level dumpster diver                                     Hobart 125EZ
Reply:I have the HD 100 and it can use the 8"/ 10# spools with the spool adapter installed.And I got the adapter at Home Depot.Miller Thunderbolt 225Millermatic 130 XPLincoln HD 100 Forney C-5bt Arc welderPlasma Cutter Gianteach Cut40ACent Machinery Bandsaw Cent Machinery 16Speed Drill PressChicago Electric 130amp tig/90 ArcHobart 190 Mig spoolgun ready
Reply:$8 spool 2" adapter, and mine fits the larger spools just fine.KRS***************************************Lincoln AC225 stick welderLincoln HD100 WeldPak flux core wire feed welderThree of the cheapest grinders money can buy
Reply:yeah my 3200 hd came with the adapterLincoln 3200HDHobart hood1 man`s junk is another man`s treasureGit-R-Done,Welderjones18
GMT+8, 2025-12-31 16:57 , Processed in 0.097934 second(s), 18 queries .
