lincoln pro cut 25
发表于 2021-8-31 22:30:15 | 显示全部楼层 |阅读模式
is this machine worth buying,ill be cutting mostly 1/4" but maybe a little thicker.220 volt operation thanks
Reply:I just sold one. It is a 110/220 volt machine. It will cut 1/4 very slowly. Actually extremely slow. 3/16 is max in my opinion. It does however have the smallest  kerf on the market.  On sheet metal there is not another plasma that cuts smoother.
Reply:how much did you sell it for?
GMT+8, 2025-12-31 15:10 , Processed in 0.101072 second(s), 18 queries .
