sa-200 for free may just live again
发表于 2021-8-31 22:30:14 | 显示全部楼层 |阅读模式
I aquired a sa-200 for the price of "come and get it" it was born in 54 or 55,sat outside for many years,hood off, rad off ,no air cleaner ,exaust pipe rusted out/gone threads and all , found all the parts except air cleaner laying around machine.hooked up battery to starter ,bumped engine over, it turned over freely.checked fuel system(line,sed.bowl,valve,etc.)plugged solid.cleaned everything including the carb,made gaskets for the carb,cleaned out the intake manifold(filled with some kind of mud cacoon/nest).Reassembled,put in fresh fuel, spun it ,nothing.Opened up mag.,blew out ,checked point gap .015,looked brand new inside,checked for spark (LOTS!!!!),pulled plugs (little dirty/rust)checked compression,cyls 1,2&4,no comp.(s$##&%$^#t) put about 3to4 oz. of ATF/diesel mixture in each cyl. let set for a week,pulled plugs spun motor over put plugs back ,hit the starter ,she fired up(on one cyl only,ran kinda rough)pulled plugs back out looked in the holes ,saw the valves stuck open in 3 of the cylinders.I tapped the valves with a brass punch and plastic hammer ,rotated engine over ,again .did this several times until the valves worked freely.Put plugs back in ,hit starter button ,didn`t spin over more than a dozen times,fired up all cyls. runs like new,no smoke and starts super easy .I haven`t tried to weld yet still trying to get gov/kickdown linkages hooked up. and I need to have rad. re-cored .  PS. GOT TO LOVE THOSE OLD ENGINESLast edited by GONWHLN; 01-10-2008 at 04:26 PM.1979 LINCOLN SA-200 (FOR SALE)1954 LINCOLN SA-200MILLERMATIC 200LINCOLN 250 TIGLONGEVITY 60 IPREMIER POWER WELDER ON 4X4BRONCOVICTOR WRENCH
Reply:it feels good dont itComplete Fabrication Shop specializing in pipe fabrication. Also offering heavy steel fabrication and sheet metal work.
Reply:Originally Posted by scubaholicit feels good dont it
Reply:Kewel...But, be careful...welders can become as addictive as crack...Smithboy...if it ain't broke, you ain't tryin'.
Reply:Originally Posted by smithboyBut, be careful...welders can become as addictive as crack...
Reply:Originally Posted by smithboyKewel...But, be careful...welders can become as addictive as crack...
Reply:Originally Posted by papa65told my wife I needed 1 for both hands  she's blonds   hope she don't see this
Reply:Update!!!!!!! machine welds in all ranges and 120v power also works,revs up,idles down  now I can spend a little money ,need radiator re-cored,need to put muffler on it (manifold threads rusted/gone----Ideas ?)sheet metal work,wire engine electrical,custom paint, fine tuning carb. and gov. and she`s ready to put to work.        I also need info on adjusting the gov.                            Thanks   Don     Last edited by GONWHLN; 01-14-2008 at 03:36 PM.1979 LINCOLN SA-200 (FOR SALE)1954 LINCOLN SA-200MILLERMATIC 200LINCOLN 250 TIGLONGEVITY 60 IPREMIER POWER WELDER ON 4X4BRONCOVICTOR WRENCH
Reply:you might try bob @weldersales he has been a great help for for these old  iron horses, if you can find one teledyne continental f model manual is a great owners manual ,  they were printed back around 1987 ,I have one and wont part with it .
Reply:I don't know what your radiator shop charges for a recore, but Northern Radiator has new for 240. Here are some links to Lincoln manuals from my website:http://content.lincolnelectric.com/p...MS/IM179G1.pdfhttp://content.lincolnelectric.com/p...IMS/IM179G.pdf
Reply:thanks for the link KSellon  . I am also looking for adjustments for the older bellows style idle actuater.1979 LINCOLN SA-200 (FOR SALE)1954 LINCOLN SA-200MILLERMATIC 200LINCOLN 250 TIGLONGEVITY 60 IPREMIER POWER WELDER ON 4X4BRONCOVICTOR WRENCH
Reply:Try this one:  http://www.mylincolnelectric.com/Cat...t.aspx?p=49818
GMT+8, 2025-12-31 16:57 , Processed in 0.071620 second(s), 18 queries .
