Looks Like This Is The End.....
发表于 2021-8-31 22:30:12 | 显示全部楼层 |阅读模式
Not sure what happened but I was welding away and all of a sudden POOFFFF!Flames came out of the motor.. Lots of smoke and then nothing.I guess I finally blew it up...Crap.Now I have to see if I can get another one......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Positioner? Hard to see.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Probably lost the ground path back to the welding machine and the welding current tried to go to ground back thru the motor and the primary wiring feeding it. Does yours have a flat braided copper strap held against the spindle with a spring?   If so did it get loose?
Reply:Originally Posted by weldermikePositioner? Hard to see.
Reply:Uuugh! Want me to bring mine to the clinic?I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by zapsterI guess I finally blew it up......zap!
Reply:Originally Posted by weldermikeUuugh! Want me to bring mine to the clinic?
Reply:They never work any more once you let all the smoke out.
Reply:Might still be salvageable. If it's just a simple AC motor, you might be able to get it rewound for a lot less than it might cost to replace it. Would depend if you have a place around that still rewinds motors..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Most positioners I have seen use DC motors with a simple foot-pedal speed control. You might find a suitable replacement motor at Grainger or AutomationDirect, etc.JohnA few weldersA lot of hammersA whole lot of C-clamps
Reply:zapsterJust pretend that it's a project that one of your more'challenged' clients brought in, and you'll do just fine.Opus
Reply:Naaaaa I am pretty sure that it is over.I did get it to function again but it only goes one speed...The forward/reverse don't work anymore and the motor still spits sparks......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Model 2A?Weld like a "WELDOR", not a wel-"DERR" MillerDynasty700DX,Dynasty350DX4ea,Dynasty200DX,Li  ncolnSW200-2ea.,MillerMatic350P,MillerMatic200w/spoolgun,MKCobraMig260,Lincoln SP-170T,PlasmaCam/Hypertherm1250,HFProTig2ea,MigMax1ea.
Reply:Originally Posted by shovelonModel 2A?
Reply:What about that place down in New Bedford that Andex brought the 1936 to have rewired?..They could probably fix the motor on it.Miller Syncrowave 180Miller 211 w/ spool-gunLincoln Ac/Dc buzzboxCutmaster 38 plasmaVictor,Smith's,and Craftsman (Harris) O/A torches.DeWalt Multi cutterFiber Metal helmets(old school)Enough Snap-On to be a dealer
Reply:New project thread titled small block chevy weld posistioner.
Reply:Hey it's only a tool. Better that then your heart .OR,  I thought you might have been on suicide watch.
Reply:Originally Posted by leadspunkNew project thread titled small block chevy weld posistioner.
Reply:A man after my own heart.Miller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:Is the motor a 90 vdc?ChrisAuction Addict
Reply:Originally Posted by DSWMight still be salvageable. If it's just a simple AC motor, you might be able to get it rewound for a lot less than it might cost to replace it. Would depend if you have a place around that still rewinds motors.
Reply:zap; seems a shame to toss the whole thing because of a faulty motor. can you at least repurpose the chuck?i.u.o.e. # 15queens, ny and sunny fla
Reply:Easiest way to dispose of it is to put it in the mail to me. I am sure to find a way to  repower it.
Reply:I have 2 angle grinders that have metal shavings inside them causing them to only work in one position.  I am going to take them apart, clean them up, and put them back together.  Hoping this will fix the issue.  Considering that the motor isn't totally fried, you may be able to do this with your positioner.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:My boss has given me the green light to start the search for a new one...After the long weekend the search begins.......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.Even better than screwing with the old one!GravelThe difference between theory and practice is that in theory there is no difference.
Reply:http://www.ebay.com/itm/Atlas-Model-...item5aff5602a2 Seems pretty good to me. Can handle 200lbs, and I like the fact it has a rheostat foot pedal. Reasonably priced as well considering what they go for.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:I'd look into this one by Team Industries.   I like it much better than any of the Aircrafter or Jetline model bench top positioners I've used in the past.  http://www.weldpositioner.com/wp440.html
Reply:Originally Posted by zapsterBig Block FORD if anything.......zap!
Reply:Originally Posted by duaneb55Cheaper to buy a new positioner and a lot less downtime.
Reply:Put these on your list. Missed out buying one quite a few years ago. Top quality..http://www.starleymfg.com/testimonials.htmEsab/Lorch ET-220iEsab 160i caddyThermal LM-200 Lincoln feedersThermal Pee-Wee 85sThermal 60i- 3phase /RPC powered (Beast)Thermal Drag-gun 35CINE 1500 Klutch 140i
GMT+8, 2025-12-31 20:01 , Processed in 0.122485 second(s), 18 queries .
