sixteen foot roof rack for a 4 door dually
发表于 2021-8-31 22:30:12 | 显示全部楼层 |阅读模式
in progress, here's today's bounty, 2x2x1/8 with a 2x1/4 tension member up top,gonna sit on a 3x2x1/4 frame on the trucks tin.. Attached Imagesface all times with a positive mental attitude,then and only then will you have done your best.
Reply:That thing is going to be able to support more weight than you can safely drive down the road with when completed. So don't try to load it to it's maximum capacity, or you may roll the truck over. I built mine with 1.25x1.25x0.125 square tubing and it will probably be able to do the same if put on a dually 1 ton. Mine is 13.5', for an extended cab 3/4 ton, 8' bed. Are you going to have a removable rear cross bar?
Reply:two rear crossbars are removable,swinging.face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Holly overkill lol going to be a beast of a rack for sure
GMT+8, 2025-12-31 20:00 , Processed in 0.180107 second(s), 18 queries .
