5mm mild steel plate drilled and cut to size fot the wheel casters mount..1.5x2mm square tube..
Reply:Then i started to weld the table legs in the frame..I lean the front legs to make it more stable..I prefer to bolt the table top..these are the fixtures that will hold the plate..
Reply:I made a mistake,i should have not welded the inside corner..it took more time to grind the angle iron to flushed in the corner..Making sure that all fixtures are level in the frame..
Reply:Nice job!-AaronJet 17.5" Drill Press1942 South Bend 16x84 Lathe1980s Miller 320A / BP --- 2013 Power Mig 2562012 Jet 7x12 Horizontal BandsawVictor O/A Setup
Reply:Done with the frame..now tapping the table top..1/2 thick plate..my table is three plate design..Ground tab..
Reply:2 pieces 2mm stainless sheet welded together with 1/16 stainless welding rod..Do not have any sheet plate in my scrap bin..So i used a solid wood as an alternative..
Reply:If budget permits..i can easily replace it with sheet plate..Prepping the frame prior to painting..Then paint it with galvacoat primer
Reply:and then...Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Second coat..yellow lemon paint..Epoxy primer gray at the back of the plate..Sanding sealer for the wood..
Reply:That's real nice!Tweco Fabricator 211i
Reply:Looks real good and funtional, nice job
Reply:sweet... real nice work .
Reply:I'm not fond of the leaning front legs just where you are working but the build is great. Actually too good looking to weld on. Better put it in the living room instead :-)
Reply:Really nice job. I like the 3 plate design for clamping in the center of a part.TOO MANY TOOLS & NO MORE SPACE
Reply:Nice Job
Reply:Looks great! Questions:What kind of wood is that and why would you paint it? It looked beautiful. Where are you located (general area or country)?Are you concerned with painting the bottom of table plates that heat might burn it off releasing noxious fumes?Sent from my SCH-I545 using Tapatalk
Reply:Very Nice!Idealarc 250AC 225SVictor OA-older made in USA stuff.And a crap ton of other stuff.
Reply:Nice!Lincoln Power Mig 216Lincoln AC/DC-225/125Miller 625 X-Treme PlasmaMiller 211 Forney 95FI-A 301HF 91110Victor Journeyman O/PMilwaukee DaytonMakita Baileigh NRA Life Member
Reply:Great craftsmanship! Truly professional
Reply:Great Job !!!
Reply:Finally! A great example of a post with enough photos to document the project step-by-step!High-Five bugeloo! Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:wow! nice and clean…
Reply:Another beautiful build bugeloo! Impressive attention to details. Well done!Going nowhere If I'm not mistaken, bugeloo mentioned here once that he's from Philippines.PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Thanks, it looked kinda tropical to me. He has a neat shop space and nice tables and stands for everything. Sent from my SCH-I545 using TapatalkNice table, well done!"All of this and some of that's the only way to skin the cat!"
Reply:Originally Posted by Going nowhereLooks great! Questions:What kind of wood is that and why would you paint it? It looked beautiful. Where are you located (general area or country)?Are you concerned with painting the bottom of table plates that heat might burn it off releasing noxious fumes?Sent from my SCH-I545 using Tapatalk
Reply:awesome |
