Metal violin
发表于 2021-8-31 22:30:12 | 显示全部楼层 |阅读模式
finished working on a new project.its a metal violin sculpture with the size of an actual violin. its a commissioned work for a  violin  collector here...body composed of gauge 20 pre painted sheets i found in a junkshop and the small details are composed of  auto transmission discards and gate flower ornament...the neck is made of brass pipe and stainless rods and the scroll was handshaped BI rod detailed with some printer gears in assorted sizes...took me at least 70 hrs to make..just thought of sharingthanks. Mario Attached Images
Reply:Very fine work!  As always...Sent from my SCH-I545 using Tapatalk
Reply:Absolutely cool!Arcon Workhorse 300MSPowcon 400SMTPowcon SM400 x 2Powcon SM3001968 SA200 Redface1978 SA250 DieselMiller Super 32P FeederPre 1927 American 14" High Duty LatheK&T Milwaukee 2H Horizontal MillBryan
Reply:Yours is an amazing talent!(Retired) Professional firefighter, amateur everything else I try to do...Oh yeah:  Go Big Red!   (You know: one of the 12 members of the Big 10 cuz we left the 10 members of the Big 12...)
Reply:Fine work indeed.
Reply:Nice job again.      Looks like it might have some weight to it too.
Reply:wow! nice job...
Reply:here is a violin, I made for my daughter a number of years back, and it sounds very nice as well,  not as fancy as the metal one tho, Attached Images
Reply:Work of art right there. Your skill and attention to detail is amazing!
Reply:Outstanding work Sir....very nice.Quality work is never Cheap, and Cheap work is never Quality!!If it's broke, and you're not, we can fix it!!  Lincoln Idealarc sp200Century 230amp ac/dcSmith O/A TorchesHuth Hyd. Pipe Benderother misc "cool" tools
Reply:One of the nicest pieces I have seen. Your work is truly inspiring, thanks for sharingMike
Reply:You got great skills man! Smooth and neat work.  Outstanding craftsmanship!PlasmaCam CNC cutterLathe and Band SawClamps
Reply:Some real craftsmen here...nice!"All of this and some of that's the only way to skin the cat!"
Reply:Very cool.......are you going to make a bow for it??? was trying to think of something cool to use, but,,,,,,blank as always......If you see me running for no apparent reason, try to keep up:"Reality" What a concept!Miller Big 40 {1972} vintage, with 150 ft. of 000 leads, old Alaskan pipline welder.
Reply:Bad ***!Now I lay me down to sleep, by the bed a Colt I do keep.Should I wake and find you inside, a coroner van is your next ride.
GMT+8, 2025-12-31 15:10 , Processed in 0.073419 second(s), 18 queries .
