Hi,I'm new to this forum and I've done nearly 1 year of welding but still learning.I have a TecArc ATIG 315P ACDC welder and the question is can someone explain to me how to fully set this welder correctly.I've been given this welder brand new and I had it only couple of months.Welding in DC is great, feels really good as well as it produces neat welds with good penetration, however I'm struggling with AC setup on this welder.Welding sheet metal such as 2 mm aly is OK however if I'm about to weld 3 mm box section it struggles to penetrate the metal on full blast and have ARC wander, but I know this welder is powerful enough for this job.If its possible can someone guide me with the setup of the 'Clean Ratio' 'AC BIAS' etc.Thank you
Reply:Welcome to the forum.Lincoln A/C 225Everlast P/A 200
Reply:Welcome aboard!I'll give you some advice that worked for me the last time a new piece of equipment had me stumped (2 weeks ago)."Read the manual"It really helped!Be wary of The Numbers: Figures don't lie,. but liars can figure.Welders:2008 Lincoln 140 GMAW&FCAW2012 HF 165 'toy' GTAW&SMAW1970's Cobbled together O/A
Reply:Originally Posted by mike837goWelcome aboard!I'll give you some advice that worked for me the last time a new piece of equipment had me stumped (2 weeks ago)."Read the manual"
Reply:Originally Posted by SlobOh NO!!! That's too much like "reading a map" when lost.......... |
