Square Bar Stock Joints
发表于 2021-8-31 22:30:09 | 显示全部楼层 |阅读模式
Thank you for the add. I would like to build an animal hauler like the one on the picture below and have a couple questions about the types of joints I need to use to get the best strength given the type of material I am using. I'm using 1/2" square bar stock (because it was free!) Below are a couple pics .Any advice is much appreciated. Last edited by ALRookie; 08-27-2015 at 06:32 PM.Reason: typo
Reply:Weld it the same way as tube- weld the joints, where the metal comes in contact. No special joints required.You'll get some added strength when you weld up the cage material to it.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:You might find the beginning of this thread of interest. I didn't even bother with bar in the corners of mine. The only thing I really bought was the heavy wire mats ( I wouldn't have even had to buy those if someone hadn't swiped the heavy mats I'd saved for the project that were leftovers... Grrr.)Cage holds 2-3 40-60 lb hogs each year when we go pick them up for 4H. The cage has 2 doors because it's easier to load them one way in the truck, but when I take the cage off and run it down the isle to the pen, the side door makes it easier to transfer them with out having to do all sorts of contortions in the barn with the lift to line up an end gate.http://weldingweb.com/vbb/showthread.php?119851-4-H-stuff.No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks, DSW
Reply:Technically speaking, I think if you are asking for the most weld strength, then the more linear weld you have, the stronger.70,000psi yield strength on a 45 degree beveled angle joint would lay down more linear weld area than a 90 degree butt joint. I am no engineer. Do you need it 45??? I don't think so.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
GMT+8, 2025-12-31 16:56 , Processed in 0.100077 second(s), 18 queries .
