Late nights in your house garage and noise
发表于 2021-8-31 22:30:08 | 显示全部楼层 |阅读模式
What do you guys do?  Push your luck until the neighbor complains?  Closing the garage doors is enough to keep grinder noise down? Maybe I need something like a port a band to cut metal silently? Right now I stop around 9.30 pm
Reply:I can work out there all night and doubtful anyone would have any complaints.Now my stereo is another matter entirely and must be used with discretion Expert Garage Hack....https://www.facebook.com/steven.webber.948
Reply:Originally Posted by engineer1984What do you guys do?  Push your luck until the neighbor complains?  Closing the garage doors is enough to keep grinder noise down? Maybe I need something like a port a band to cut metal silently? Right now I stop around 9.30 pm
Reply:insulate and dry wall the interior walls of your garage. I started off in my 2 car garage, it was insulated and sheet rocked, even the over head door was insulated. Never had noise complaints.Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:engineer1984  When is it too late?A grinder is not a primary weld fabrication tool . . .If you are grinding at all - let alone at night - it generally means you have done something wrong . . . Why are you telling all of your neighbors - you have done somethingwrong?Succinct: weld-fab technique - and good social skills - have a link.'Grinding, and grating' - are not well received - respect your neighbors.Run Silent - Run Deep . . .Opus
Reply:I think the grinder is the single loudest tool I have.  I try to shut it down around 9 or 10pm.  I may fire it up for a few seconds if I absolutely have to until 11pm.  I shut the air compressor off at 10pm.  Most of my closest neighbors are empty houses.  I've told the others to just tell me if I'm disturbing them.  They know that I will work all night pretty often, and to some extent, I think they appreciate somebody being up and on the lookout.  We've had some break ins and thefts in the last few years that have gone unsolved.The biggest thing is to stay on friendly terms.  I help them out when I can and have probably fixed something for everyone in town by now (small town, maybe 200 or so people).  When they have downed branches or their mower quits, or they need something hauled to the dump.  I wander over and do what I can.  I really try to stack up my noisy work during the day and concentrate on machining, painting, welding, and wrench turning at night.My name's not Jim....
Reply:I guess I'm lucky, all my neighbors are far enough away that the noise I make doesn't bother them. I do make their lights dim when I strike an arc though...My "collection":Homemade Stick WelderVictor O/A TorchAC 225Ideal Arc 250HF 90 Amp Flux CoreHF Mig 170Solar 2020 Plasma CutterPower i-Mig 140EHarris O/A torchHF Dual Mig 131140STAlpha Tig 200x
Reply:I usually try to get off the noisy stuff around 9. Friday night is different than a weekday though, I was out until almost 11 last night. Some of my neighbors have a habit of sending up mortars until about 2Am a few times a month though so the rest of us are conditioned a little. Whenever I think I'm being rude to the people around me I'll shut it down. I'm just tinkering and learning too. If I had a real project to work on all bets would be off. Oh and a grinder is a primary tool when you first start out. Just thought I'd throw that out there. lolMillermatic 180Hypertherm PM65 083300CandCNC Dragon Cut Linux 620-4 Bundle with Linux Computer Precision Plasma Magnum HD 5x5 Gantry kit
Reply:My barn is in my backyard, insulated pretty good. I have been out here 2 or 3 in the morning and every weekend morning around 5am. On a side note my one neighbor is an A-Hole and that's the way I have my Bluetooth sound bar facing. I might accidently turn the music even more and open the door when he is around...oops
Reply:No neighbours close to me. That's what's nice about being in a non residential rural farm area. I do what I want, when I want. Honestly though, it's getting more rare that I'm out in the shop past 8:30 or 9 pmJasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:whether it's the stereo or grinder noise i'm of the opinion that if the neighbors can hear it then it's too loud.  i would hate to sit in the yard and hear fabrication noise coming from my neighbors so i give them the same courtesy.i.u.o.e. # 15queens, ny and sunny fla
Reply:Originally Posted by engineer1984Push your luck until the neighbor complains?
Reply:when im upstate, I have no neighbors to hear anything...the deer dont complain, back on the island..11pm ..then ill cut down on the noise......seems everyone else has there parties and blast music till all hours of the morning, so that gives me the right to make my own kind of music..tools humming away....Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:I don't personally push it all and once nine hits I start getting cold sweats if I run the grinder or the cold saw too much.  Garage is cinder block.  Insulating doors are a good idea.  I'm sure insulting the walls would help too.And I hear you, I hate grinder noise too.  Good idea on the hack saw.  Then you can files to remove burrs (or a deburring tool).I'm just a hack.  Full-time computer job and creative hands on welding, etc at night.  Would like to work in the garage as long as possible. I tend to plan the project so that all welding and silent stuff is late night stuff.
Reply:We have "smart" meters up here on residential hydro services, also referred to as #*&%#&! meters by some people.  Prime time rates are almost double the nighttime rates and run from 700 am until 700 pm.  This is our clueless, corrupt provincial government trying to please all the green people in Toronto.  Rates in this province are so high that industries are shutting down and moving or going out of business, while no new companies will locate here.  Ontario has gone from  the richest of all Canadian provinces to a poor one.This causes a lot of people to start cooking dinner, bathing, doing laundry etc after 700 pm.  This includes senior citizens, poor people and cheap b**t**ds like me. This makes it hard to be quiet by 800 or 900 pm for the sake of the neighbours if you are trying to weld, grind, pound a hammer or run your compressor and power tools.Weekends and stat. holidays are all "off peak" hours, so I try to do most of the jobs at the house then, sure makes it hard to do much during the week though. I am voting with my feet, I've bought a property outside the city limits, won't have to worry about any neighbours out there (none nearby) once I get a place built and move there. Residential hydro power is still the same, though a 3 phase hydro line runs through my property, might go with that depending on the costs."The reason we are here is that we are not all there"SA 200Idealarc TM 300 300MM 200MM 25130a SpoolgunPrecision Tig 375Invertec V350 ProSC-32 CS 12 Wire FeederOxweld/Purox O/AArcAirHypertherm Powermax 85LN25
Reply:live somewhere without neighbors! if i were you, i would use more oxy-fuel, just because it is quiet. plus it is something that you can challenge yourself in usingLast edited by IslandWeldingKid; 08-29-2015 at 12:32 PM.VictorPraxairAir LiquideMillerLincoln Electric
Reply:I usually try to shut it down by 8pm, I am good to my neighbors, they are good to me.Ranger 250 thick stuffHobart Handler 140 not thick stuffthe pane and oxy setup
Reply:With my garage closed up, nothing is really all that loud.  I've been out until midnight or later and you really can't hear much. Even my compressor running is no big deal.  The only thing I try to avoid running is my plasma table unless I can have the garage door open.  That's more to keep from smoking myself out instead of annoying the neighbors.  I usually like to make my late night projects the welding and machining portions.  I can tig and use the mill and lathe all night long if I want.  And I live in suburbia.
Reply:I'm on a corner lot so only 1 neighbor to deal with. I've asked if the noise bothers them and they seldom hear it. The fact that I clean the snow from their sidewalk with my garden tractor all winter, and help out with their small repair jobs probably influences it too.If you don't want to stand behind our Troops, feel free to stand in front of them.
Reply:I don't think my  neighbors can even hear a gun shot. But when others are sleeping in the house I don't fire up the compressor or grinder unless I really need to for a couple minutes.
Reply:You definitely need to stay on your neighbors good side.I had one that cranked his motorcycle and stereo  up at night, if someone was loading his stuff up, the noise has damaged my vision.
Reply:Was wornoutwelder your neighbor?^^
Reply:Exactly why I moved to the country.  Unfortunately for the "neighbors" they built a housing tract 1/2 mile away but still in the middle of the country.  I had been in my 200+ year old house with a few hundred acres around me for a month or so. A buddy of mine comes over and we are shooting pistols since he just got a new one. Sheriff pulls up just as we were finishing after an hour or so, probably 8PM in January so DARK. I ask him what's wrong, he usually doesn't work this section so he doesn't know if there is a noise ordinance/quiet time but the neighborhood down the road called the complain.  We were done anyway so I didn't press him. I was at town hall the next day for permits, etc. I ask the clerk about the shooting/noise ordinance. She says "There is none beyond that your car has to have a muffler. You can do whatever the hell you want. You want to shoot at 3am, knock yourself out and tell the deputy if they come back to tell the complainers that they shouldn't have moved to the country."So now I grind and bang on stuff whenever I want 😀Sent from my SCH-I605 using TapatalkRyanMiller Multimatic 200 tig/spool gun/wireless remoteMillermatic 350P, Bernard/XR Python gunsMiller Dynasty 350, Coolmate 3.5 & wireless remoteCK WF1 TIG wire feederMiller Spectrum 375 XtremeOptrel e684Miller Digital EliteMiller Weld-Mask
Reply:Originally Posted by xryanExactly why I moved to the country.  Unfortunately for the "neighbors" they built a housing tract 1/2 mile away but still in the middle of the country.  I had been in my 200+ year old house with a few hundred acres around me for a month or so. A buddy of mine comes over and we are shooting pistols since he just got a new one. Sheriff pulls up just as we were finishing after an hour or so, probably 8PM in January so DARK. I ask him what's wrong, he usually doesn't work this section so he doesn't know if there is a noise ordinance/quiet time but the neighborhood down the road called the complain.  We were done anyway so I didn't press him. I was at town hall the next day for permits, etc. I ask the clerk about the shooting/noise ordinance. She says "There is none beyond that your car has to have a muffler. You can do whatever the hell you want. You want to shoot at 3am, knock yourself out and tell the deputy if they come back to tell the complainers that they shouldn't have moved to the country."So now I grind and bang on stuff whenever I want
GMT+8, 2025-12-31 16:56 , Processed in 0.116761 second(s), 18 queries .
