Dialarc 150watt 15ohm Rheostat Body
发表于 2021-8-31 22:30:06 | 显示全部楼层 |阅读模式
Available for shipping costs or would like a bad one with good shaft/wiper assembly for same shipping costs so I can make a complete assembly.This one fits the Dialarc series and was missing the "guts" but windings are like new.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Hello Duane,I would like to get this rheostat from you. I live in Andover, Ma 01810. I don't think it's exactly the same as the rheostat on my HF-P seems to have a small section (probably from 1-3 on the dial) where the contacts are closer together but ohms is ohms and in general this should work. I'll probably never need to fine tune anything that precise but you never know. For now I have mine repaired as I had 2 broken contacts (the last 2) near what would probably be about 9.8 on the dial but they will most likely eventually let go as it's tough soldering steel!. Now if I could tig it with another machine I'd be all set! Anyways, if this is still available it will probably make for a more solid repair as a bit of vibration will probably ruin what I did. I believe the values of the rheostat are the same. I'll have to confirm. In the meanwhile can you send me your contact info and or paypal info, phone or whatever so I can get out what you need for this out to you.Thanks and thanks for posting the part!Art
Reply:Gone.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
GMT+8, 2025-12-31 16:57 , Processed in 0.071795 second(s), 18 queries .
