ACE INDUSTRIAL PRODUCTSModel 73-6011200 cfm, high volume fume extraction & filtration capacity Designed for shopfloor use with the mobility to move from workstation to workstation 10 ft. extraction arm with articulated joints designed to hold position for hands free use Wide mouth source capture hood Heavy Duty steel constructionBuilt in spark trap for fire safety Durable casters, two that swivel and lock for stability Filter status gauge Built in AC outlet to power other tools or accessories UL Listed Made in USA Dimensions: 52"L x 29"H x 26"W Weight: 305 lbs. FUME EXTRACTORS EXTRACTION ARMS EXHAUSTER / BLOWERS Pre-Filter, General Use , 20" x 24" x 4" 91-956 Pre-Filter, Charcoal Odor Control, 20" x 24" x 2" (use w/ 91-955) 91-937 MAIN FILTERS(Main Filter, 95% Efficiency, General Welding, 20" x 24" x 12" 91-853 Nozzle/Hose/Arm Assembly, Mobille Fume Extractor 65028 10' Replacement Hose, Mobile Fume Extractor 65029 Caster, Swivel, Each, Mobile Fume Extractor 65030 Handle, Mobile Fume Extractor 65061 ACCESSORIES Dual Arm For Two User Operation, Mobile Fume Extractor 99-799 Our most powerful mobile fume extractor also has 360º arm rotation for maximum reach and flexibilityACE 73-601 MOBILE FUME EXTRACTOR |
