Stick and Alum
发表于 2021-8-31 22:30:04 | 显示全部楼层 |阅读模式
Just to see how it would work and look I p/u some Hobart 1/8 4043 rods (10 pack... The stick  Gods and I have not met yet ) And went to town on some 1/8 alum. that I have, I set the Red AC/DC to 70 amps, for no burn thru, and the beads looked good. Now what is the best way to remove the slag ?? so the weld will look some what nice...I will try and get some close up pict. later
Reply:Originally Posted by Thats HotNow what is the best way to remove the slag ??
Reply:CEP----You're supposed to be the nice one. Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:Lets see the beads. The amps you are suggesting sound way low for 1/8" alum rods, and most guys I know have a real tough time getting decent welds with them.Stick alum welds super fast and even guys who can weld with stick well have trouble keeping the arc length short enough as fast as they burn..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:I' am nice. That slag is tough to get off. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:I went back up and did a lap joint and turned the heat to 85 amps, I think I am moving to slow and the alum is to thin. The amps jump 75,85,ect and I have the camera on charge. I will have some pict up on Fri. and yes the slag is a pain to remove.It nice to just try this with a 10 rod pack..I am not sure if I can find a 4043 in 3/32 or if they make them in that size.
Reply:I have some 3/32" rods in alum. I forget exactly what amps we were plying with them at, but I'd start with those in the 85-95 amp range and go up. 1/8" I'd be even higher.Welding 1/8" alum using 3/32" rods was a big challenge. You had to drop your arm really fast. Maybe 1-2 seconds to burn a whole rod, 3 tops. Slag removal was fair at best even with getting everything as close to perfect as possible..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:Thanks for all info Guys.....
Reply:I couldn't remember what I did. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:You have to be one desperate man, to weld with alumi stick rods.I guess that's what we have....~JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:I gotta bring some of these to the next Weld-o-rama just for $hits and giggles.   Got them free and ain't never going to use them.     Best aluminum stick bead?  Could make a fun drinking game.....Sent from my SCH-I545 using TapatalkTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I think I am moving to slow and the alum is to thin.
Reply:Originally Posted by Thats HotI went back up and did a lap joint and turned the heat to 85 amps, I think I am moving to slow and the alum is to thin. The amps jump 75,85,ect and I have the camera on charge. I will have some pict up on Fri. and yes the slag is a pain to remove.It nice to just try this with a 10 rod pack..I am not sure if I can find a 4043 in 3/32 or if they make them in that size.
Reply:Aluminum. One second it's there, the next it aint. I keep some of that 2000 aluminum brazing rod around and use my torches. It's about as good as anything if you aren't a tigger.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:It was just something I was trying.I won't be makeing any $$$ on alum.... I have a MM252 and a MM211, if I ever would try to do some work with alum. I would just p/u a spoolgun. As of now I am happy fixing mower decks here in sandy Fl.
GMT+8, 2025-12-31 16:56 , Processed in 0.073142 second(s), 18 queries .
