New to me idealarc 250
发表于 2021-8-31 22:29:56 | 显示全部楼层 |阅读模式
Picked up a idealarc 250 it a very nice welder welding with dc compered to ac is like night and day. I cant believe i waited so long to get a dc stick welder. it was a little rough on the outside, but inside was a little dusty but i cleaned it out and lube the gearsit has three sits of caps in it, two in the back by the fan and one in the front  a few questions how do you tell if it has the power factor caps in it? and where does the ground cable and work cable go from left to right? Attached Images2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:If I understand your question...the work lead ("ground") is on the left.
Reply:Ground cable on left, stinger cable on right.These machines are very good scratch start tig welders as well on dc- polarity. I use dc+ for all stick welding.Call lincoln and run your numbers by them to confirm your question on the power factor caps. Typicaly a C in your numbers indicates factory installed power factor caps.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Originally Posted by fhsfiremanco1two in the back by the fan
Reply:thanks guys I'll post better pictures when i get the chance. I got some 7018+++++ from the stream fitters at work anyone have any tips for running this on the idealarc?2-Lincoln idealarc 250/250, lincoln 225 ac/dc welder, lincweld ac 180c, hobart handler 210, hobart stickmate lx 235/160, Hypertherm Powermax30local 26 I.B.E.W Electrician
Reply:I don't know what all the ++++++'s are, but keep 7018 at a real close arc gap. You virtually drag it touching the puddle. Take your time, wait for the puddle.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
GMT+8, 2025-12-31 16:56 , Processed in 0.071728 second(s), 18 queries .
