Rookie with a question
发表于 2021-8-31 22:29:54 | 显示全部楼层 |阅读模式
Cant get around my whole Garage with my Harbor Frieght Mig. Seeing as how I havent had the chance to install my second 220 outlet. Even if I do I cant reach everything I want. Where Can I get a longer gun/ground cable I can throw on them? Or should I just fab a longer cable to plug into the wall?"The credit goes to the man who's actually in the arena..."
Reply:Just make an extension for the 220 v line..... or add some outlets.  The problem with moving welders in my garage is that I only have narrow walkways left for maneuvering.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:just make an extension cord but be forewarned they get pretty expensive depending how long ya make em 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:Not planning on going too long, it woul be nice to get more distance from the welder to the work though, so I dont feel so crowded."The credit goes to the man who's actually in the arena..."
Reply:I don't see the need to reach everyplace in the garage with the gun, unless you are still welding the metal  frame of a new building that is to become the garage.Be aware that stray sparks can and will get into every  crack in a wall, into every pile of rags, into anything that's flammable, so it is often best to do your welding in the middle of a cleared area.
Reply:true true. I have a plan as to how to set up my new bench. Still want to do some more practice before I spend the big cash on the plate for a bench top and whatnot. These days, theres not alot of it."The credit goes to the man who's actually in the arena..."
Reply:http://weldingweb.com/vbb/showthread.php?t=11537
Reply:make a cord
Reply:the longer the gun the more problems with pushing the wire through it...
Reply:If you MIG has a separate power source and feeder... you can always get longer conections for those units... and keeping the power source static, move only the wire feeder. That way you can get arround the problems mentioned by weldbead because the lenght of the mig gun stays the same.Mikel
Reply:Originally Posted by Mikel_24If you MIG has a separate power source and feeder... you can always get longer conections for those units... and keeping the power source static, move only the wire feeder. That way you can get arround the problems mentioned by weldbead because the lenght of the mig gun stays the same.Mikel
GMT+8, 2025-12-31 16:56 , Processed in 0.096086 second(s), 18 queries .
