Bending and welding square tube aluminum
发表于 2021-8-31 22:29:52 | 显示全部楼层 |阅读模式
Can anyone coach me a bit about what kind of aluminum alloy will have the bending properties to allow something close to 90 degree bends with say a 8 - 10 inch radius?There would also be some welding involved and its been so long since I did any aluminum I'm not sure any more what rod to get.... I have a  heli-arc setup, a  squarewave with builtin Hifequency unit, so plenty of welder but maybe a little light in skill department far as `weldor' is concerned.My work has vastly been with various steels.  And even then haven't picked up a heli-arc since I retired in 2000.
Reply:6061-T6 would bend well (if you have a bender that fully supports the square tube in the dies)on an 8-10"  radius. It could also be done without a bender, but it wouldn't look as pretty.4043 is commonly used for 6XXX series aluminum.RexLast edited by rode2rouen; 06-03-2011 at 07:48 PM.
GMT+8, 2025-12-31 18:25 , Processed in 0.098786 second(s), 18 queries .
