Can you TIG with a Lincoln AC/DC 225/125 K1297?
发表于 2021-8-31 22:29:52 | 显示全部楼层 |阅读模式
?Thanks!
Reply:It's possible with additional equipment but in my opinion it would be like saying you can arc weld with 2 batteries and a set of jumper cables
Reply:Yes, in fact you can Tig with virtually any CC power source though it's capabilities may, as in this case, be limitedThe difference between art and craft is the quality of the workmanship. I am an artist.
Reply:It will work quite well, but will be "scratch start."  It may not do the greatest on AC, because having continuous HF helps to stabilize the AC arc, and keep it from just dying out.http://www.az-zbum.com/welder.upgrade.shtml
GMT+8, 2025-12-31 18:25 , Processed in 0.104130 second(s), 18 queries .
