115 volt dc
发表于 2021-8-31 22:29:49 | 显示全部楼层 |阅读模式
can i use a 4.5 inch grinder in the 115 volt dc outlet on my sa 200 or will it mess it up? if i cant is there anything i can do to make it put out 115 volts AC.? does anyone make a 115 volt dc grinder i searched google and found nothing
Reply:You might be able to, most tools use Universal motors, which can be run on DC or AC. If its a cheap grinder then I say what the heck, give it a try.
Reply:As long as it has brushes it should work.  Some new fangled governed ones do not.DavidReal world weldin.  When I grow up I want to be a tig weldor.
Reply:Scubaholic, Glad to hear you got the beast going!Most motors with brushes are okay. Plain old incandescent lights are okay. Some newer electronic controls are not okay. Nothing with a transformer will work.
Reply:Most tools in a weldors arsenal are fine off an SA-200, read the tag to make sure it doesn't say AC only.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Most variable speed tools will NOT work. Most single speed tools will work.
Reply:as in will not work, will burn the tool up or just wont work?
Reply:It will fry the trigger on a variable speed drill.
Reply:I discussed this at some length with the local power tool repairman a few years back. This is what he told me: if the switch goes click it will work on dc, if it doesn't the switch will burn out in short order. If it is a variable speed tool it must be made for dc.The difference between art and craft is the quality of the workmanship. I am an artist.
Reply:I know dewalt, makita and milwaukee make ac/dc grinders and such. I have both dewalt and makita grinders currently and also have a milwaukee  bandsaw. ~is ac and - is dc. however, i did have a makit 4.5 grinder that was ac only with a clicky switch that got fried by being used on a sa200. it was a brushed motor, too. make sure it says ac/dc!http://www.makita.com/menu.php?pg=product_det&tag=9005Bhttp://www.dewalt.com/us/products/to...roductID=10649http://www.milwaukeeconnect.com/weba..._192206_192137these are a few of the tools i'm referring to.Last edited by banshee35; 02-02-2008 at 08:29 PM.Reason: grinder link
Reply:My portable put out 120V DC and I use my grinders, hammer drill, band saw, anything with brushes.Lincoln Power Mig 200Ready Welder spool gunLincoln Tomb Stone AC DCMPM 150 AMP DC portable Arc welder and GeneratorRiland 40 AMP Plazma Cutter
Reply:If it has brushes and just an off-on switch it will work. Having said that I've run into a problem with that on two tools. One was the first Makita 4 1/2' grinder ny dealer received and I bought. The switch was rated barely above the amperage the tool pulled on AC. Fried the switch, Makita fixed it, promptly fried it again. I found a switch rated for twice the AC amperage it pulled and replaced it. No more problem and the grinder lasted over twenty years. The other was a Victaulic groover and was the same thing. Replaced with a larger amperage rated switch and no more problems.
GMT+8, 2025-12-31 18:45 , Processed in 0.077467 second(s), 18 queries .
