Jd 450 upper heel replacment
发表于 2021-8-31 22:29:45 | 显示全部楼层 |阅读模式
Had to remove this damaged upper section.Replaced with a 1/2'thk ar 400 pc.Also moved the lifting ring up about 8"to get it out of the impact zone.These guys are ripping ledge.This is how I spent my Saturday and couldn,t go to Zaps tig clinic,maybe next time guys.Also 1 pic of the side cutters I built out about 7 weeks ago.Buckets a CF Central Fabricators. Attached ImagesLast edited by admswelding; 05-27-2014 at 09:26 PM.
Reply:Seems like these buckets keep you busy...You could say you have BUCKETS of work!HA!
Reply:Originally Posted by Canadian WeldingSeems like these buckets keep you busy...You could say you have BUCKETS of work!HA!
Reply:Do you bend your replacement panels on site?   Are you bending the repair panels or farming that part of it out?Miller BobcatHarris cutting outfitMiller spectrum 625 plasmaVariety of shopmade tools
Reply:nice work! yeah how do you go about bending your replacement plates?R.T. Welding LLCOn Site ServiceColumbus, NJ
Reply:They get bent by my steel supplier.How you guys think you gonna bend 48"of 1/2" ar in the field???
Reply:Bend it with an excavator.  Seen it done many time though never on purpose or with any degree of accuracy. GravelThe difference between theory and practice is that in theory there is no difference.
Reply:On a lower section I have used the machine to add little radius.Have also used the teeth to take some out.But in upper area gonna be tuff after you got it tacked in.Waste alot of time messing around.Now if you have another machine and operator that's a different story.You can be right there to tack up,no running back and forth Bs.
Reply:Originally Posted by GravelBend it with an excavator.  Seen it done many time though never on purpose or with any degree of accuracy.
Reply:Very nice job. You sure do have some tallent to do that kind of work.Sent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:Originally Posted by Chris T.Very nice job. You sure do have some tallent to do that kind of work.Sent from my SPH-L710 using Tapatalk
Reply:Originally Posted by admsweldingI gotta ask.. Have you ever done one of these ?By looking at the list of your equipment,I,m going to guess NOT...  Reason I ask, you seen it many times....
Reply:Not starting a argument sorry if it came off that way.All I do is weld these things I have very little hrs running them.You are correct about needing to be precise.After being bent in a press brake I still spend a lot of time fitting up.It gets frustrating at times,maybe I,m just to fussy about it.But my name is on it so I want it to look right.
Reply:You came across a little strong but I have thick skin. Not much gets to me.I've seen someone with your desire to have it as perfect as possible. It didn't look fun at all. I'll stick to building shelves, carts, and other BS in my garage and leave the important stuff to those of you who have that level of skill.I ran a 330 with a 5 yard bucket digging a 20,000 cu yd retention pond. The bucket wasn't right and it sure made it more difficult. My hat is off to you for not just slapping it together and calling it good.GravelThe difference between theory and practice is that in theory there is no difference.
GMT+8, 2025-12-31 18:43 , Processed in 0.096945 second(s), 18 queries .
