finished a roof rack today
发表于 2021-8-31 22:29:45 | 显示全部楼层 |阅读模式
face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Nice but how rigid is the front part? I know plumbers typically carry PVC pipe so weight would be less of an issue.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:iron-mike"finished a roof rack today" - and you are starting the repair tomorrow!Opus
Reply:it's made from 1/8 x2x2 st,1/4 x2 straps , sitting on a 3x2 x1/4 angle base,stronger than you can imagine, i have a similiar one on my old duelly that handles all you can give it.face all times with a positive mental attitude,then and only then will you have done your best.
Reply:btw, rigid with capitol letters!face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Looks good but I was quite curious how sturdy the front part is.
Reply:That is Saweeeeet~!Regards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:Originally Posted by Ironman50Looks good but I was quite curious how sturdy the front part is.
Reply:Originally Posted by iron mikeit's made from 1/8 x2x2 st,1/4 x2 straps , sitting on a 3x2 x1/4 angle base,stronger than you can imagine, i have a similiar one on my old duelly that handles all you can give it.
Reply:Originally Posted by Robert HallI'll bet you can't sit an elephant on it, but I think it would hold 100lbs fine.
Reply:Only missing in case of elephant.  LolRegards,RobGreat Basin WeldingInstagramBlue weldersRed weldersMy luscious Table DIY TIG Torch cooler
Reply:1/8 2x2 with a 2x1/4 tension member does no need any gussets at all.face all times with a positive mental attitude,then and only then will you have done your best.
Reply:Good work, Mike! How much does it weigh?  Might want to make something similar for my 1/2 ton someday.GravelThe difference between theory and practice is that in theory there is no difference.
Reply:good question,prolly 360 or so poundsface all times with a positive mental attitude,then and only then will you have done your best.
Reply:if i put a baby elephant you'll buy a bottle of whisky huh?so while your drinking whisky in michigan,i'll have an elephant in my truck in california,makes sense, i'm quite certain now that you are a welder!face all times with a positive mental attitude,then and only then will you have done your best.
Reply:the problem with whiskey is that after a while you start to see elephants,so , that's why i don't drink whiskey .so it stands to reason that if a guy has an elephant in his truck, he's already got whiskey and won't need yours!  lolface all times with a positive mental attitude,then and only then will you have done your best.
Reply:Why so high off the roof?
Reply:Nice rack.  lol I need to make myself one of those for my truck. Chad
GMT+8, 2025-12-31 20:07 , Processed in 0.181134 second(s), 18 queries .
