Miller welder overhaul job
发表于 2021-8-31 22:29:45 | 显示全部楼层 |阅读模式
This is a miller that iam rebuilding...going on 2 years now...evertime I start ...I find a new projuct...My mind is starting to forget how it all goes...Does anybody have a instruction book? or just wing it :} Attached ImagesRobert D
Reply:2nd Attached ImagesRobert D
Reply:last Attached ImagesRobert D
Reply:I hope you knew the electric end of the machine was good before you started rebuilding.  I have 1 with a good engine and a BAD rotor that I need to get pulled apart.  I don't think the manuals are available on line for Roughneck, but I do have the direct # here for the guy at the factory who knows them inside and out if you need it.I also have a dealer who has a few of them in the back room for parts, so I think I can get a good rotor for mine.  Since I have a Bobcat, the roughneck is kind of a back burner project.Appreciation Gains You Recognition-
Reply:Robert DIf you go to www.Millerwelds.com home page under service & support select owners manuals. You can down load them or request a printed copy. Need model and serial number. It looks like they have them listed going back many many years! Hope this helps.
Reply:Thanks for the infoRobert D
Reply:try  that link.   http://www.millerwelds.com/service/ownersmanuals.php
Reply:You're sure to have a few parts left over when you get that back together.
Reply:Is this machine still in pieces TEN YEARS later? Has it been reassembled and used again yet or not?
Reply:lol!!!!  i can't figure how i managed  to answer that thread 10 years later, if i recall it was ont the recent threads page....confused,
Reply:thank-you 7a749 i'm so prone to distractions i tought being guilty again
Reply:I've heard the constant cold can make some Canadians slow on the draw but DANG snowbird! MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Thank-you duane your southern warmth attitude conforts me ...well sort of...steve i think it's aging...a slow but surely  degenerative process, ask me how i know
Reply:Originally Posted by snowbird i think it's aging...a slow but surely  degenerative process, ask me how i know
GMT+8, 2025-12-31 18:45 , Processed in 0.092719 second(s), 18 queries .
