Bought new machine and set up shop
发表于 2021-8-31 22:29:44 | 显示全部楼层 |阅读模式
Hey guys just bought myself a tig finally got a syncrowave 210 and so far so good just a little confusing but just wanted to share it and I set up a section of my parents basement(I'm only 22 for those wondering why my parents basement)  to do Home projects and side work when it comes in. Looking to getting a few moreTools, but getting there! Ignore my messy scrap bin lol but there is a plasma cutter and stick welder in that picToo
Reply:Looks like a pretty nice start up situation you've got going for yourself.   Congrats.
Reply:What kind of ventilation do you have?  In a basement, that would be important...
Reply:A good ventilation setup is important as are some fire extinguishers.Lincoln Idealarc 250Millermatic 200Big *** O/AHypertherm 45AHP Alpha TIG 200XA very large bag of Hammers
Reply:Working on vent system right now have big exhaust fan running out the door we have a walk in basement from the outside
Reply:that wood paneling is scarring me to death when you mention  "plasma cutter " ..... be careful. nice start on machines..
Reply:aside from the above mentioned concerns , i like your shop.  life has taught me, that a large shop means youll drag more stuff home ,small and uncluttered works well congrats on the venture
Reply:Youse some metal roofing....Makes a good wall guard...Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:It is a nice looking shop. I like the assortment of bench grinders. The arbor press needs to find a permanent home post haste.
Reply:Very nice.  I like the broom.  I'd add fire extinguishers and do ZERO woodworking down there.  Sawdust plus mig sparks in a basement, even with that broom, no good.
Reply:Nice shop. Let the man do what he is doing. He isn't a moron, why does everyone have to nitpick and put in there two cents? I am all for the suggestion of some ventilation but give all the other comments a rest, jeez.HTP Invertig 201Lincoln Idealarc SP250Miller 180 AC StickBy farmall:They should have held the seagull closer to the work, squeezing evenly for best deposition.
Reply:If you have the room for a 12x16. Shed. You might be safer. We tiled the floor in one and hardy backered the walls. Ran power for lights and machine.  It's cheaper to burn down the shed then you mothers house.   Also I would be afraid that smoke seating itself into the wood.  Leaving a odor over time. Sent from my HTC One_M8 using TapatalkMiller Bobcat 250Miller Maxstar 140strLongevity 140 migSnapon Muscle Mig/tigHypertherm Powermax 30
Reply:Looks like you got a good smart .  Its great to get every ones advice and go from there to make it work safely, efficient and enjoy your first shop.
GMT+8, 2025-12-31 18:45 , Processed in 0.067506 second(s), 18 queries .
