What's this lathe worth?
发表于 2021-8-31 22:29:42 | 显示全部楼层 |阅读模式
I can pick it up for $1000 wasn't really in the market but it's not every day a local shop closes down and sells everything.  What would you say it's worth?  ThanksSent from my iPhone using Tapatalk
Reply:Better grab it for that money good price and good lathe.  John Sent from my XT1254 using Tapatalk
Reply:Originally Posted by johnrbauerBetter grab it for that money good price and good lathe.  John
Reply:I would...is it 3 phase or single phase power?250 amp Miller DialArc AC/DC StickF-225 amp Forney AC Stick230 amp Sears AC StickLincoln 180C MIGVictor Medalist 350 O/ACut 50 PlasmaLes
Reply:What's the difference between a regular lathe and clausing lathe?Torchmate 2x2 CNC with Flashcut CNC controlsHypertherm Powermax45 Esab ET220i Razorweld 195 MigRazorweld 200ac/dc TigTormach 770, Tormach xstechRazorweld, Vipercut/Vipermig, SSC Foot Pedal Dealer
Reply:Originally Posted by GambleWhat's the difference between a regular lathe and clausing lathe?
Reply:clausing is just a name brand....like,logan or atlas..Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Originally Posted by roadkillbobbclausing is just a name brand....like,logan or atlas..
Reply:Good value at $1,000. What are you waiting for? Even if it is three phase, you can build a rope start rotary phase converter for just the price of a 3 phase motor.Miller Millermatic 252Miller Syncrowave 200Liincoln AC-DC 225Victor O-A Set
Reply:awsome Originally Posted by Gerry1964SNAP
Reply:Nobody here can say what its worth. On the surface it seems like a good deal and that makes a guy wonder.
Reply:Originally Posted by mikecwikNobody here can say what its worth. On the surface it seems like a good deal and that makes a guy wonder.
Reply:its worth what you want to pay for it....a picture doesnt show if its working or not and what might be worn or in need of repair....if its what your looking for and need it , its worth more that buying as a second or third lathe..it comes down to a personal decision...and how often they come up for sale close to you..if you have to spend a day traveling add that expense to the cost, if its around the corner from your house, pay more but less in travel and moving it expense..it all evens out in the end..Of all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:I would give $1500.00 and up depending on condition and tooling.  John Sent from my XT1254 using Tapatalk
Reply:If it was the one piece of worry more but he has several ovens. Lathes (one is about 12 feet long) just a ton of stuff several of most things he is retiring and closing shop.  Has to have everything out by end ofMonth I expect prices to drop more.Sent from my iPhone using Tapatalk
Reply:Originally Posted by hog guts  Has to have everything out by end of Month I expect prices to drop more.Sent from my iPhone using Tapatalk
Reply:End of September....  I just found out about the stuff when I decided to stop by end of the week.  Not a matter only if it's a good deal in sure it is, it's a matter of whether it's worth a $1000 to me and how much I'll use it.  Just wanted to start by asking if you all thought it was a good deal now I need to decide if I'll use it.  ThanksSent from my iPhone using Tapatalk
Reply:You'll find uses for it. Then you'll find you need a bigger one for the new things you want to use your now toSmall of a lathe for. Regards-Carlo
GMT+8, 2025-12-31 18:43 , Processed in 0.100075 second(s), 18 queries .
