WTF is wrong here?
发表于 2021-8-31 22:29:38 | 显示全部楼层 |阅读模式
Started welding some stainless yesterday. I can run 7018 uphill all day. I had good results with welding 1/8" 309L-16 rods on 12" sched 40 304 with 309 tabs when I started yesterday. Approx 90 amps, AC. Had to stop and reset machine to burn some 7018 for an emergency repair. Welds looked like this before reset...After reset, they globbed up in the middle with no fill on the sides. Tried going up and down on amperage, cleaned area for ground to bright metal, tried stringer and weave. No improvement. WTF am I doing wrong?Sent from my iPhone using TapatalkUsing Tapatalk
Reply:Your not using the same side to side oscillation and pausing on the sides as you were.JasonLincoln Idealarc 250 stick/tigThermal Dynamics Cutmaster 52Miller Bobcat 250Torchmate CNC tableThermal Arc Hefty 2Ironworkers Local 720
Reply:Am I weaving too fast? Too slow? I'm the only welder at my job, so I don't have anyone to critique my technique. I have no experience with stainless stick, so I'm at a loss here. Sent from my iPhone using TapatalkUsing Tapatalk
Reply:DCEP is preferred polarity.  Did you try that or is machine AC only?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:I thought stainless was supposed to be run AC??Sent from my iPhone using TapatalkUsing Tapatalk
Reply:It might work on AC.I've only run 1/8 309's, the ones designed for flat ONLY.Do you happen to get a box of the -17's???You didn't say which brand of rods....But here's the pdf on Lincolnhttp://www.lincolnelectric.com/asset...9L-17/c656.pdfThey can't go uphill. I found that out.Stainless rods are an art.But....Try them on DCEP.Here's Jody's video, on Stainless Rods uphill.http://welding-tv.com/2014/02/06/sti...tainless-tips/~JohnJust a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:AK, thanks. They are lincs, -16Sent from my iPhone using TapatalkUsing Tapatalk
Reply:Will try DC and report back. Sent from my iPhone using TapatalkUsing Tapatalk
Reply:Originally Posted by Nashvegas WelderAK, thanks. They are lincs, -16
Reply:-15 is for all positions-16 is for all positions except downhill-17 is for flat and horizontalAs duaneb55 has already said, DCEP is the preferred current.
Reply:Thanks guys. Sent from my iPhone using TapatalkUsing Tapatalk
Reply:So, the 15 is fast freezing for downhill.Could you use them like 6010 for root passes????Anyone???Just a couple welders, big hammers, grinders, and torches.Work will free you.Men in dirty jeans built this country, while men in clean suits have destroyed it. Trump/Carson 2016-2024
Reply:good video! It has been a long time since doing SST vertical. Was for a mild steel pad eye to manganese plate test. Took some practice...TOOLS AND TOYSSMAW Mid States Inc. "MISSING LINK" 10-150 AMP Buzzer circa 1945ishSMAW Magic Wand 40-60 AMP Suitcase Buzzer circa 1939ishGMAW Hobart 210 IronmanOxy-Propane TorchMany other old and cold goodies"Rusty but Trusty"
Reply:NashvegasWelder....not really understanding your pictures.  My browser shows the first as a downhill...is this pic an upside down view of three passes uphill?  Any chance 3/32" rod was used for this?  The second pic is an attempt at uphill with 1/8"....big difference.  That's going to be a tougher then normal uphill ss weld due to the fact that the lug is narrowing out as you pass center.  I would go with two passes (stringer and weave) uphill 3/32" rod.  Lot less aggravating.
Reply:I switched it over to DCEP and now I can weld!Sent from my iPhone using TapatalkUsing Tapatalk
Reply:How's this for a decent root pass on flat?Sent from my iPhone using TapatalkUsing Tapatalk
Reply:Hey good to see you got it figured out Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:Me too. It means I get to keep my job for a little while longer. The great thing about being the only person here who can do anything more than booger weld is that to those who've tried, a mediocre weld looks amazing as long as it doesn't fail!Sent from my iPhone using TapatalkUsing Tapatalk
Reply:MUCH BETTER!!!!Sent from my iPhone using TapatalkUsing Tapatalk
Reply:I was just wondering ...what type of projects would require stick welding SS? can u fill me in ?
Reply:good ol' stainless stick. I can't count the number of times I've seen my older brother throw a test coupon to the ground and stalk off.
Reply:I dont know about states, but this part of the world stainless stick welding is used much in paperfactories.They like it becouse it is a cheaper and faster way to make welds compared to tig welding.Most of stainless in here is welded with stick. And nash can you turn that pipe while you weld? If you can I would recomment you try to go slightly downhill, it comes out much nicerlooking weld.
Reply:Originally Posted by trap_tech9I was just wondering ...what type of projects would require stick welding SS? can u fill me in ?
Reply:Originally Posted by SvetsareI dont know about states, but this part of the world stainless stick welding is used much in paperfactories.They like it becouse it is a cheaper and faster way to make welds compared to tig welding.Most of stainless in here is welded with stick. And nash can you turn that pipe while you weld? If you can I would recomment you try to go slightly downhill, it comes out much nicerlooking weld.
Reply:I didn't do much pipe welding on anything over 2" handrail before I started my job here. Primarily flat and structural, so this has been a true learning experience. This stainless has thoroughly whipped my butt, but I've come back swingin!Sent from my iPhone using TapatalkUsing Tapatalk
GMT+8, 2025-12-31 18:24 , Processed in 0.385007 second(s), 18 queries .
