Alternative To Gas Valve On Torch Handle???
发表于 2021-8-31 22:29:37 | 显示全部楼层 |阅读模式
Has anyone here tried to make up some kind of foot operated gas valve to provide an alternative to the typical hand operated gas vavle???
Reply:no, but I must ask why would you?bosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:Don't know why you would do a pedal operated valve, but I do find torches with out a valve are much more comfortable to use; for myself anyway.Sent from my SGH-T989 using Tapatalk
Reply:Huh? you either need em or not, and if not just leave them open.I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by 92dlxmanno, but I must ask why would you?
Reply:I dunno, im sure its possible. I personally like my torch valve. makes a handy place to rest a thumb! plus, as I alternate pressure, it makes that cool WOOSH, whoosh, WHOOSH, whoosh, WHOOSH sound.for the places I have to go, I could not use a pedal. but for fun, im trying to think of a vertical stroke valve besides a gate or a globebosses stuff:trailblazer 325maxstar 200my stuff:sa 200fronius transpocket 180100 amp Lincoln w/f97 f350 DITKevin
Reply:I have a micro switch on my scratch start tig set-up. I converted an old Sears ac stick machine to a water cooled dc tig welder . I run a gas solenoid valve that has a 110v coil and use the switch to control power to the valve to start gas flow. I have been thinking of a foot switch instead of the switch on the torch.
Reply:http://forum.weldingtipsandtricks.co...s+valve#p27442http://forum.weldingtipsandtricks.co...s+valve#p28426Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
GMT+8, 2025-12-31 16:56 , Processed in 0.100340 second(s), 18 queries .
