versamill lathe converter
发表于 2021-8-31 22:29:35 | 显示全部楼层 |阅读模式
anyone faimilaiar with this device?it attaches to toolpost to let lathe do milling operations..has two muiltirange pulleys like on a drill press,  etc..selling for $350..
Reply:I've never used one but I know what you're talking about. What all pieces do you have. The full setup had a lot of different pieces. Any pics?Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:theres one pic on craigslist..new york-hudsonvalley-tools for sale wed jun 01--..id post it here but no idea how..looks like the offer includes three pieces..appreciate the help, if this is a good piece of equipment to go with my old south bend i'd go get it... did a little web research i see  what you mean about how much tooling there is ...Last edited by weldbead; 06-02-2011 at 08:44 AM.
Reply:I'm not sure if I found the one you're looking at but one came up on the Pittburgh craigslist along with a Bridgeport head, saw sharpener, and gear puller.   If that's the one then it's just the head itself. Still probably worth the $350. However if you've just got a small Southbend lathe then I don't think you could really use it. It's pretty large and really needs a pretty good sized lathe to mount it.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:not the same, the one im seeing is reasonable scale to ride my little ten inch sb..
Reply:Ok. I'd still question whether the carriage on a 10" would be heavy enough for much milling but I guess if you took small cuts it would be ok.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:On modern cnc machines they call this live tooling For the money it might be a handy device. Won't realistically replace a good mill. Could be handy for machining the ends of shafts, especially with the indexer included. I could think of a few times something like this would be handy.Versamil is still around so you could likely talk to them http://www.versamil.com/Irish... here's the photo and description:model c master lathe converter this goes on tool post to make lathe capable of milling machine work good shape ...includes high speed head and headstock divider/indexer. Attached Images
Reply:Originally Posted by forhireOn modern cnc machines they call this live tooling For the money it might be a handy device. Won't realistically replace a good mill. Could be handy for machining the ends of shafts, especially with the indexer included. I could think of a few times something like this would be handy.Versamil is still around so you could likely talk to them http://www.versamil.com/Irish... here's the photo and description:model c master lathe converter this goes on tool post to make lathe capable of milling machine work good shape ...includes high speed head and headstock divider/indexer.
Reply:Originally Posted by weldbeadthanks, how do you do that with the picture?
Reply:$350 is dirt cheap if it's all there. I've used them for portable machining, keyseats, way milling & lots of boring.Matt
Reply:Ok that picture shows a lot more to it. Yes that setup is worth the money. If I was closer and had the money I'd grab it.   I have used a indexer from one of those sets and it was handy sometimes.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:If you want to know more about the unit, there is a guy, Brian who either owns or manages Versamill. He is on the Practicalmachinist.com website. His username may be brian@versamillGranthttp://jackalopefab.com/MM210Synchrowave 200DXMiller XMT350 w/60series feederMiller Bobcat 250 with SGA 100 and spoolgunHTP PlasmaFull Machine shop with everything
Reply:Originally Posted by Matt_Maguire$350 is dirt cheap if it's all there. I've used them for portable machining, keyseats, way milling & lots of boring.Matt
Reply:based on yours and forhire's comments this aint what im lookin for..many thanks
Reply:I didn't think it was what you thought it was. I do wish it was closer but oh well I don't need to be spending any money anyway.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:A Versamill is a milling, drilling, grinding and slotting attachment.  I had one in my machine shop kit back in 1974 in the Army.  I used it on a 11" Rockwell lathe and it worked great.  Not a heavy duty piece of equipment but versatile.  Used for OD and ID grinding, indexing, milling flats, tapers, key ways and drilling holes while the part is still in the lathe.Russell
GMT+8, 2025-12-31 20:06 , Processed in 0.119605 second(s), 18 queries .
