Weld & Power G3000LX how much?
发表于 2021-8-31 22:29:35 | 显示全部楼层 |阅读模式
How much should I expect to pay for one that is working? Have they been out of production for a long time? I found a parts pdf and an operator pdf but theres not much out there and Lincoln calls it "obsolete"ThanksMiller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:Weldanpower 225 became the Ranger 8.Mine has a Briggs 16hp, plenty of parts to be found as far as the engine is concerned.G series are newer than mine (1989) I paid 650.00 for mine, other than some carb work ( thanks Ethanol ) runs good and welds better than the Bobcats at work...Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Max, Thanks for the reply. The one I am looking at only has a 9HP Briggs. It is rated at 3,000 watts and DC welding from 50 to 125 Amps. I know it is a tad on the small side but it is light enough to be portable by one person and I would not need more than 3,000 watts unless our house went down for a long time which is very unlikely where we live. I normally only need to power a jobsite tool.The seller is asking $600 (they lowered it from $700). I have not contacted them yet.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:what are the specs on yours?Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:Ooooh... Now I know your machine in question... Mine has 6k watt, 210amp DC, 225amp AC. I was helping someone else earlier with a "G" series unit which happened to be a newer version of mine- hence the confusion.Ive recently seen a weld-and-power but it was AC only. Ive also seen the Power Arcs, 3000 and 5000. Both AC only, Im curious to know more about it.Briggs parts will be easy to ascertain, its the machine itself you may have troubles finding parts.Im still hunting for brushes for mine, just in-case my go bad....:edit:Just found PDF, looks like an older Ouback 145.  I was leaning towards an Outback, but I wanted the 100% duty cycle, hence my WP.Last edited by MadMax31; 06-05-2011 at 05:18 PM.Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:Maybe I should wait for a bigger one to come along. The best thing about this one is that it only weighs 190 lbs, do you know how much the bigger 16HP units weigh?Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:Mines easy 550lbs. Glad my neighbor has a Kubota to yank it off my truck when needed....It has a cart, whelbarrow style, which is fine for me. I just use it at the house.Lincoln Power MIG 210 MP ( boat anchor )Lincoln Weld-Pac 100 HDHobart IronMan 230Cutmaster 42Jackson NexGenSumner Ultra ClampsDWM120
Reply:I just contacted the seller, he said it starts and runs fine and has 325 hours. I am going to look at it over the next couple days.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:Well I got it! It is in great shape, 325 hours. Starts easy, welds great. The seller is a retired guy who used to seal abandoned mine shafts and caves for the US Forest service. It has a full roll cage and a custom base with big wheels. It would get flown in by helicopter and set down at the job sites. I also got an ammo box full of parts like new air cleaner elements, spark plugs, fuel additive, wrenches etc. He also gave me a set of 25' extension leads. Very nice guy and didn't really want to sell it but has no more use for it.Now my biggest issue is loading/unloading it on my work van. It weighs 250 lbs with the roll cage and wheels. I am considering Harbor Freight ramps or a Harbor Freight truck crane adapted to fit my receiver hitch. The back doors on my Royal hi top utility body open to about 5 feet wide and just under 6 feet high, so I think a truck crane might work.Miller Challenger 172Miller Thunderbolt AC/DC 225/150Miller Maxstar 150 STLVictor 100CVictor JourneymanOxweld OAHarris O/ASmith O/A little torchNo, that's not my car.
Reply:bigb, sounds like you got/made a good deal - should provide you a whole new capability.Enjoy!Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
GMT+8, 2025-12-31 16:57 , Processed in 0.072979 second(s), 18 queries .
