bosch PS-31-2A drill and driver
发表于 2021-8-31 22:29:34 | 显示全部楼层 |阅读模式
Just purchased a new drill-Bosch PS31-2A.I have never owned a Bosch of anything so I thought I would give it a try.It was on sale at my local Lowes home improvement store for $99.99,was $134.99.I know people hate HF but sometimes you get lucky and get a solid performer like this Drill Master 9.6 volt drill.I have had this thing for 7 years and have built 1 battery pack for it.It was under powered but just used here at home,nothing professional but it has done the job for me.This new drill is 12 volt lithium-ion and only weighs in at 2 lbs with battery.I have heard some good things on here about bosch tools so I hope it lasts as long as the old Harbor freight.The only thing I am going to do to the bosch drill is to get a 1/2" chuck for it being it is only 3/8" chuck just because I have some 1/2" step bits and what-not to use and need a 1/2" chuck.I put a Jacobs 1/2" chuck on the HF drill but it won't work on the bosch because it takes a 1/2"-20 chuck and not a 3/8"-24 like the HF one does.I can get a good Jacobs chuck at lowes for about $25 so I might go and get one tomorrow.I would have bought a chuck today but I wanted to be sure I was going to keep the Bosch,I think I will,I like it.It is only 12 volts but it has alot of power plus it is 2 speed.It comes with 2 batteries and a soft case. Attached ImagesMaxus Pro-125 MigChicago Electric 90 amp DC flux-coreLincoln Electric AC 225 tombstoneO/A torchM/O mini-torch10 acres of flatland15 acres of holler
Reply:that's supposed to say PS30-2A not 31Maxus Pro-125 MigChicago Electric 90 amp DC flux-coreLincoln Electric AC 225 tombstoneO/A torchM/O mini-torch10 acres of flatland15 acres of holler
Reply:Well I went to lowes this mornin and got a 1/2" chuck for my new bosch drill,ready to do some drillin. Attached ImagesMaxus Pro-125 MigChicago Electric 90 amp DC flux-coreLincoln Electric AC 225 tombstoneO/A torchM/O mini-torch10 acres of flatland15 acres of holler
Reply:Nice modification. I never thought of changing the chuck, a 1/2 chuck would be handy.  How long do the batteries last on your Bosch?
Reply:Originally Posted by forhireNice modification. I never thought of changing the chuck, a 1/2 chuck would be handy.  How long do the batteries last on your Bosch?
Reply:Originally Posted by dugndeepthat's supposed to say PS30-2A not 31
Reply:Lithium batteries generally have a 5 year life span or so regardless of use. They are pretty good batteries for drills hey don't mind too much about charge cycles as they don't have much of a memory at all.Anyways pretty nice device I've been thinking about picking up a small Milwaukee 1/4" shank driver pretty cool little things, spindle lock allows you to use sockets manually if you run out of juice.Hope it provides you years of service.
Reply:I need to get my coupon for my free bosch PS20B pocket driver sent in,it's either a free battery,flashlight or the pocket driver,I think I will go with the pocket driver,it's like what 65535 is talking about,1/4" shank,put sockets or whatever will fit 1/4"Maxus Pro-125 MigChicago Electric 90 amp DC flux-coreLincoln Electric AC 225 tombstoneO/A torchM/O mini-torch10 acres of flatland15 acres of holler
Reply:Just a fyi (you guys probably know this) Rigid from Home Depot have a lifetime warranty to include the batteries my batteries would die after 5 minutes I brought into a Rigid repair shop they replaced both batteries with just a smile (they did test em)
Reply:I wasn't satisfied with the look of the 6000 series chuck I bought and put on the bosch,didn't like the green stripes,so I went and got a Jacobs 5000 series drill chuck,looks a whole lot better,works the same,I like my stuff to function and look good also(lol)Some are probably thinking.....just let it go(lol) Attached ImagesMaxus Pro-125 MigChicago Electric 90 amp DC flux-coreLincoln Electric AC 225 tombstoneO/A torchM/O mini-torch10 acres of flatland15 acres of holler
Reply:Personally I've never been impressed much by ratcheting plastic body chucks. Always prefer metal sleeves and non ratcheting. Then again I'm a fan of keyed chucks and Albrecht keyless.
Reply:This 5000 series chuck is the 2 sleeve all metal chuck plus it has serrated jaws with Hammerlock.It clicks 5 or 6 times as it gets tighter on the bit. Very good chuck for the money.I used to not like keyless chucks either until I got one of the better jacobs.The regular keyless chucks will start to slip after some usage,I used to get so pissed off when I would have to get 2 pairs of channel locks just to tighten the chuck up to get it to stop slippin then again to get the bit back out of the chuck.  www.jacobschuck.comLast edited by dugndeep; 03-30-2010 at 07:57 PM.Maxus Pro-125 MigChicago Electric 90 amp DC flux-coreLincoln Electric AC 225 tombstoneO/A torchM/O mini-torch10 acres of flatland15 acres of holler
Reply:Have to echo this. I've got the PS-40 driver and it's awesome.bosch cordless
Reply:First I bought a PS31 Liked it so much went and bought a PS41 I can't believe how much Tork these little tools have If I would have known about these 12V Drills and Drivers I don't think  I would have bought the 18V Bosch But that is also a Real Power House It will twist your wrist . As my Batteries are dying on my older cordless tools I am replacing with all Bosch Lithium tools  Made in Malasia. Oh well
GMT+8, 2025-12-31 18:24 , Processed in 0.098606 second(s), 18 queries .
