just bought a pm 350 mp and i think its messed up
发表于 2021-8-31 22:29:32 | 显示全部楼层 |阅读模式
Please tell me my brand new welder isnt messed up... i went and bought all the plugs for it so i could plug it in and use it.  It turns on goes through its warm up and the small display on the bottom is the only one that works, or turns on atleast. the wire speed display and the volt/ trim meter do not light up, the volt/trim meter did light up 2 times and read 0000 for what i remember and hasnt turned on again. I set the mode on # 5 which on the chart inside the cover says is for mig welding and it welds but no readouts on the meter.
Reply:I felt extra nosey and looked through a small hole in the side of it and saw that it appeared to be a partially unplugged, further investigation revealed it was in fact unplugged. i am all set
Reply:It's all messed up! Better send it to me....I'll even pay shipping.....I'm so jelous!Yeah, yeah, I know you are a weldor too. But, are you a good one?
GMT+8, 2025-12-31 16:57 , Processed in 0.098157 second(s), 18 queries .
