ranger gxt drain valve problems?
发表于 2021-8-31 22:29:31 | 显示全部楼层 |阅读模式
Hey guys, my ranger gxt keeps leaking oil out of the oil drain valve and it only has 200 hours on it!, any body else have this problem?
Reply:Did you turn and lock the valve or did you just put the plastic cap on......
Reply:Originally Posted by CruizerDid you turn and lock the valve or did you just put the plastic cap on......
Reply:That unit has a 3yr warranty on it, Lincoln is pretty good about backing their product. I believe I have the part number for that item on that Kohler CH22 if you need it.Yeah, yeah, I know you are a weldor too. But, are you a good one?
Reply:Thanks guys, I sent lincoln an e-mail, and they replied back within 2 hours and said that even though my wleder is out of warranty, they are sending me a new valve! now that is customer service
Reply:Lincoln has always handled all of my needs very well.......I'm glad to hear that you are fixed up......Yeah, yeah, I know you are a weldor too. But, are you a good one?
GMT+8, 2025-12-31 16:56 , Processed in 0.100507 second(s), 18 queries .
