Made a little coupon holder / practice stand.
发表于 2021-8-31 22:29:29 | 显示全部楼层 |阅读模式
I built a practice stand a while back from scrap and was never really happy with how it turned out.Had been building this one in my head for a while and since it was raining this weekend, spent the day in the shop making it.Started out with a scrap part from the lathe as the base. Turned the o.d. to fit inside the Speedrail tube.Next came the angle plate to bolt it to my table. When the table was built I added the 4 bolt hole plate knowing I'd use it for something like this.I then machined a piece to go inside one of the Speedrail fittings that had a 3/8" threaded hole to attach the material clamp (beam clamp).Sent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:After some more measuring, sanding and painting it was done.Flange mounting bracketMaterial clampGun/stinger/torch holder. A HF mig gun holder removed from its magnet base.Ground & V.S. lead clamping bracketSent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:Underside of gun holder bracketMore of the clampIt has an arm for the coupon and another underneath it to rest yourself onSent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:The finished productIt swings around the top of the table when I wheel it back inside.More of the lower halfSent from my SPH-L710 using TapatalkTOO MANY TOOLS & NO MORE SPACE
Reply:nice one…
Reply:@ Chris T - very nice design and fabrication.  Continue the approach and build/integrate some 'platens' into your stand for training 2F/G and 3F/G on plate.  "Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Originally Posted by jureamnice one
Reply:WOW, kid you do very nice work! You'd have no problem working in a fab shop.Don’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Originally Posted by 7A749Nice little setup.I've always been lazy & just tacked it to a piece of angle welded to a pole Turned out really sweet man.
Reply:Originally Posted by Chris T.I'm now the shop foreman for a small fab shop
Reply:The funny part is my dad has always done woodworking. He still don't know where I picked up metalworking/weldingAT LEAST IF WE SCREW UP IT CAN BE WELDED BACK TOGETHER.TOO MANY TOOLS & NO MORE SPACE
Reply:Originally Posted by Chris T.The funny part is my dad has always done woodworking. He still don't know where I picked up metalworking/weldingAT LEAST IF WE SCREW UP IT CAN BE WELDED BACK TOGETHER.
Reply:Great job bud, very pro.  I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Originally Posted by storemanGood point.  Nice work. I'm trying to transition from wood to metal.Jerry
Reply:Originally Posted by Chris T.Probably the same way I do it>Have to build some 2x4 shelving, half the nails get bent over to hold the grain together and the other half actually do something.Impact driver & screws are my friend
Reply:Great job on the stand. richey
Reply:CEP, you give new meaning to "grab a bigger hammer"!Thanks RicheyTOO MANY TOOLS & NO MORE SPACE
Reply:Yup, carried a claw hammer all the time, but only used it to beat on shackle pins, or Bardon bells. Attached ImagesDon’t pay any attention to meI’m just a hobbyist!CarlDynasty 300V350-Pro w/pulseSG Spool gun1937 IdealArc-300PowerArc 200ST3 SA-200sVantage 400
Reply:Will do, I have so many projects in the shop it's hard to get anything finished.Currently working on>Material storage rack>Mobile base for my horizontal milling machine>Storage system for under my South Bend>Mag drill baseTOO MANY TOOLS & NO MORE SPACE
GMT+8, 2025-12-31 20:10 , Processed in 0.103140 second(s), 18 queries .
