New work bench
发表于 2021-8-31 22:29:29 | 显示全部楼层 |阅读模式
So I started a new project today. This is not a welding table, but I'm going to mount a vise, drill press, and grinder on it. Made with : legs-1 1/2" square tube in 14g, cross-members-1" square tube 14gI'll put some expanded steel in as a shelf, the top will be MDF with a hardboard surface trimmed in a 1x2 I used my Lincoln Weld Pac 100 in MIG and for gas I used co2 for the first time. Wanted to try it, not too shabby. Used my Dewalt metal cutting saw, as pictured, it worked great. Cut all tube on single battery. Will cut some plates for the legs and install some casters. Top will be  2'X4'Did I read that you can spray the mig tip with Pam cooking spray? Sent from my iPad using Tapatalk
Reply:Sent from my iPad using Tapatalk
Reply:And my welds are getting better still. Couple buggers, but I'm getting better every time. I'll make two of these I hope, and a rolling cart for my table saw.Sent from my iPad using Tapatalk
Reply:That's awesome. I can't wait til I get a few more tools so I can really get to work.
Reply:Thanks, what kind of tools are you looking to getSent from my iPad using Tapatalk
Reply:Good job, Bluehunter.You will enjoy having a work table, but you will not have enough. My shop has several tables, but never a clean surface.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:Thanks, well how true, but I am working on it. Wife won't let me do any cutting on patio, I have to go out in the grass, cause the metal rusts the sidewalk. I bought a Rubbermaid shed from home Depot last week. So I could take all my tools out of the extra bedroom, and I going to make a few of these on wheels, so I can roll them around to work and still have good work surface. I was standing on that frame this morning and I'm a big guy, 250. It's strong and level. I'm doing the top today, maybe the expanded steel shelf as well. And casters. Now that I have started welding. And I have lots of carpentry tools, these will be great. Sent from my iPad using Tapatalk
Reply:Nice work..
Reply:That will be great. Maybe think about using receiver tubing instead of mounting permanent . I bought a 18'' long piece ,cut into 6'' pieces, drilled holes , and added nuts for bolts with a ''T'' for tightening and wrapped the end. Where I wanted it to extend further I welded regular square tube to it. Just mentioning. It always seems to me you never have enough flat surfaces.
Reply:Originally Posted by BD1That will be great. Maybe think about using receiver tubing instead of mounting permanent . I bought a 18'' long piece ,cut into 6'' pieces, drilled holes , and added nuts for bolts with a ''T'' for tightening and wrapped the end. Where I wanted it to extend further I welded regular square tube to it. Just mentioning. It always seems to me you never have enough flat surfaces.
Reply:[QUOTE=Bluehunter40;4254181]You lost me, got a picture?Check these postings out. http://weldingweb.com/vbb/showthread.php...=receiver+tubehttp://weldingweb.com/vbb/showthread.php...=receiver+tubehttp://weldingweb.com/vbb/showthread.php...=receiver+tubehttp://weldingweb.com/vbb/showthread.php...=receiver+tubehttp://www.harborfreight.com/18-in-l...ube-69815.htmlhttp://www.northerntool.com/shop/too...2402_200442402http://weldingweb.com/vbb/showthread.php...=receiver+tube
Reply:Really nice, well doneSent from my iPad using Tapatalk
Reply:It's always nice to see someone actually take the time to properly clean and prep their material before welding. One of my biggest pet peeves is people welding through rusted or mill scaled material because they don't want to take the time to prep.Well done.Visit Tensaiteki.com
Reply:Is that cordless dewalt saw ok to cut steel with? Arent the rpms a little too high?Sent from my iPhone using TapatalkLincoln Pro Mig 180HF Stick/Tig Inverter WelderLincoln AC225s
Reply:[QUOTE=Spicytuna;4255561]Is that cordless dewalt saw ok to cut steel with? Arent the rpms a little too high?I don't know about that one but we have a 18 volt Dewalt that is specifically made for metal. We have only use it for flat sheets of 10 gauge, 1/8''.
Reply:Oh sweet. Didnt know dewalt made a cordless circular saw specifically for metal. Sent from my iPhone using TapatalkLincoln Pro Mig 180HF Stick/Tig Inverter WelderLincoln AC225s
Reply:[QUOTE=BD1;4256091] Originally Posted by SpicytunaIs that cordless dewalt saw ok to cut steel with? Arent the rpms a little too high?I don't know about that one but we have a 18 volt Dewalt that is specifically made for metal. We have only use it for flat sheets of 10 gauge, 1/8''.
Reply:Originally Posted by SpicytunaOh sweet. Didnt know dewalt made a cordless circular saw specifically for metal. Sent from my iPhone using Tapatalk
Reply:Be careful where you store your tools..... someone may decide they like your tools more than you. When it comes to guns and tools, you can never have enough locks and security.Qualified & experienced at welding scrap metal
Reply:Ya how true, just don't let me catch them, I'm loaded for bear. Sent from my iPad using Tapatalk
Reply:Originally Posted by Bluehunter40Ya how true, just don't let me catch them, I'm loaded for bear.
GMT+8, 2025-12-31 16:56 , Processed in 0.094241 second(s), 18 queries .
