Why Should You Guys Have All The FUN????
发表于 2021-8-31 22:29:28 | 显示全部楼层 |阅读模式
I know...I know...I said in the past that "Welding Cans Together Is Just A Waste Of Time"....Well........IT IS!!!!However seeing as I never tried this I had all sorts of time to waste today so I decided to give it a shot..Now take into consideration that I basically "Just Did It"..No practice no nothing.Used the same torch set up that we used at the clinic 2 weeks ago..3/32" red but REALLY sharp...# 6? cup...Set the machine on "Daze"....45 amps max..No special prep but did rinse them out with hot water before starting..(Ya never know what is hiding inside those used BEER cans...)Unlike you guys that use this huge filler (1/16") I chose to use .035 5356 Mig wire straightened out with the drill and vise..One more thing...I KNOW this would have been much better with a positioner avoiding all these stops and starts but mine is in pieces at the present time...Well then.... Here are the picsAll things considered....It was not all that difficult.I dont need no STEEENKING PULSE!!!!!...zap!Last edited by zapster; 06-05-2014 at 03:29 PM.I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:That is great considering you didn't use 120% backround current with 77% upslope on a triangulated sinewave with 444 pulse per second on the blue lightening setting that was put back on factory default with 92% balance. Great job Steve! Step on it and go! I hate being bi-polar it's awsomeMy Heroes Have Always Been Cowboys
Reply:Yes I agree. I'd rather empty them.
Reply:YAY !  Well. More productive than voting, I reckon.Bubble gumTooth pixDuct tapeBlack glueGBMF hammerScrew gun --bad battery (see above)
Reply:So let me get this straight. Your saying that welding cans together IS fun????Hobart 125 EZHobart Handler 140Everlast STH 160Generic 210 Amp Welder/GeneratorHobart Air Force 500i plasma cutterChinese 50 amp plasma cutter! Youtube Channel : Henrymac100
Reply:Originally Posted by HenrymacSo let me get this straight. Your saying that welding cans together IS fun????
Reply:zap...........you getting those results first time out shows that guys like me are always trying while guys like you are a natural. Just out of curiosity..........how did you keep your arc from wandering?As soon as the arc wanders I burn a hole in the area above right be fore the next radius.
Reply:How is the paint not burnt?
Reply:Not impressed.  You didn't purge, you probably have sugared inside....it will never hold
Reply:Originally Posted by rahtreelimbszap...........you getting those results first time out shows that guys like me are always trying while guys like you are a natural. Just out of curiosity..........how did you keep your arc from wandering?As soon as the arc wanders I burn a hole in the area above right be fore the next radius.
Reply:Originally Posted by Drf255How is the paint not burnt?
Reply:Originally Posted by CraboNot impressed.  You didn't purge, you probably have sugared inside....it will never hold
Reply:LOL, no one will ever catch me welding cans together, #1 I probably can't do it#2 I don't want to
Reply:Originally Posted by weldermikeThat is great considering you didn't use 120% backround current with 77% upslope on a triangulated sinewave with 444 pulse per second on the blue lightening setting that was put back on factory default with 92% balance.
Reply:I guess the reason I haunt this place is because the crazies make me feel at home.life is good
Reply:The only good can, is a FLAT can! Stupi ahhloomeenumm!City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Alright, so we all know tig welding cans together is easy.. Who will be first to stick weld them??Airco Ac/Dc 300 HeliwelderMillerMatic 200 (stolen)Miller Maxstar 150STLMiller AEAD200LE (welding and generating power) Hobart MIG
Reply:But did you empty the cans yourself just before welding? That is the extra angle that gets most guys I think. I consumed all of mine before the attempt, livin on the edge!
Reply:Originally Posted by VPTBut did you empty the cans yourself just before welding? That is the extra angle that gets most guys I think. I consumed all of mine before the attempt, livin on the edge!
Reply:Originally Posted by 7A749Yous guys are awesome......
Reply:Originally Posted by 7A749Hey! That's my line!!
Reply:Originally Posted by tanglediverThe only good can, is a FLAT can!
Reply:I can't weld them so I'll stick to drinking them. That is what I do.
Reply:Originally Posted by pin2hotI prefer full ones myself.  In the process of being emptied is ideal!Originally Posted by zapsterNope found them in the recycle bin..Besides!It's Heinekin out of a bottle or Nothekin!Good thing I took the time to rinse them out because out came that "3 Month Old" bacteria funk gathered at the bottom..Just imagine what that would have smelled like with all that heat!!...zap!
Reply:Originally Posted by FORTEALLOYOh, I get it, the pipeliner approach!Hot Tapping.... up the ante a little bit. When 6G on empty beer cans becomes boring, try it with a full/sealed one.Any sort of burn-thru will be spectacular.
Reply:I bet you wouldn't even be able to get a puddle started.
Reply:Originally Posted by Fnord5I bet you wouldn't even be able to get a puddle started.
Reply:Originally Posted by MinnesotaDaveI expect you're correct, which means I wouldn't have to wait long to start laughing - blow out nearly instantly
GMT+8, 2025-12-31 20:07 , Processed in 0.113459 second(s), 18 queries .
