Other uses for Tungsten???
发表于 2021-8-31 22:29:25 | 显示全部楼层 |阅读模式
Has anybody taken some Tungsten and put a sharp tip on it and then cast a lead bullet around it?I had a guy ask me for Tungsten for that purpose. He was shooting through 2 inch solid steel discs I made for him to hang. Swinging targets. I didnt believe him until he gave me the discs back. Holy sheep shooters. 7mm rifle.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:the military makes bullets out of the depleted uranium from rectors as it goes through anything....then breaks apart and give radioactive poisoning to whoever is still alive...as far as tungsten..I have a few stuck in the ceiling after shooting them with a rubber band...lolOf all the things I lost I miss my mind the most...I know just enough about everything to be dangerous......You cant cure stupid..only kill it...
Reply:Envisioned militaristically in the 50s, hypersonic rod bundles of tungsten traveling orbital velocities would reign kinetic destruction from above.  An estimated TNT yield of 11T from a 0.3m diameter by 6.1m long rod weighing 18,000 lbs and impacting at Mach10 was touted.Reference.  Robert Heinlein's sci-fi classic, The Moon is a Harsh Mistress, is an awesome read and variation on this theme.Last edited by ManoKai; 08-31-2015 at 07:39 PM.Reason: spelling"Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Curious as to what size tungsten he was looking for?
Reply:give him some thoriated tungsten so he will have a small radiation cloud just like the big boys do  on impact. and his backyard will become a hazmat site
Reply:My high school electronics teacher saved tungsten filaments from high wattage light bulbs. He claimed that with enough tungsten, he could build an x-ray machine. True story, he showed me his mason jar with a pile inside 3/4" deep.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Some surplus 7.62x54r ammo is steel core, and boy do they penetrate. I imagine with the added mass of the tungsten you'd have a pretty serious round on your hands. Not sure about the legality though, a tungsten core would definitely put them in the AP category.
Reply:I don't remember what size he wanted. I didn't supply him. I just told him where to get it and to not say what he wanted it for. He called me for many things. I made some money off of him and his company a few times. Usually with little effort on my part.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by ManoKaiEnvisioned militaristically in the 50s, hypersonic rod bundles of tungsten traveling orbital velocities would reign kinetic destruction from above.  An estimated TNT yield of 11T from a 0.3m diameter by 6.1m long rod weighing 18,000 lbs and impacting at Mach10 was touted.Reference.  Robert Heinlein's sci-fi classic, The Moon is a Harsh Mistress, is an awesome read and variation on this theme.
Reply:Tungsten core round are armor peircers lead smashes tungsten penetrates to secure a kill shot Sent from my VS980 4G using TapatalkLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:I wonder if a guy could drill and insert just as a test run."The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:I wouldn't see why not maybe epoxy it in the drilled hole to secure it .?Sent from my VS980 4G using TapatalkLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:I would think the width of the tungsten would have to be greater than we typically tig with in order to form a large enough wound channel.  Of course, if you put enough tiny holes all the way through a person, they would eventually bleed out.Miller Syncrowave 350Millermatic 252/ 30A spoolgunMiller Bobcat 225g w/ 3545 spoolgunLincoln PowerArc4000Lincoln 175 Mig  Lincoln 135 Mig Everlast 250EX TigCentury ac/dc 230 amp stickVictor O/AHypertherm 1000 plasma
Reply:Internal bleeding balistic vest chest trauma plate a500 chest shot 1/8 tungsten to the heart Sent from my VS980 4G using TapatalkLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:If it goes yaw upon entry then you have a pretty big gash inside of you Sent from my VS980 4G using TapatalkLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:for added effect, drill a small pocket in the tip of a large caliber round, and put a primer in the pocket (backwards, so it fires when it hits the target). Haven't tried tungstens yet, might give that a try...
Reply:The pendulum for the 10,000 year clock is made from tungsten due to it's high density and low thermal expansion. (This is an enormous mechanical clock that will tick for 10 millennia without any human intervention or gas/electricity, etc)http://longnow.org/clock/Last edited by MikeGyver; 09-01-2015 at 03:05 AM.Welding/Fab Pics: www.UtahWeld.com
Reply:I remembered reading about steel flechette darts when i was a kid and looked this up.Dave J.Beware of false knowledge; it is more dangerous than ignorance. ~George Bernard Shaw~ Syncro 350Invertec v250-sThermal Arc 161 and 300MM210DialarcTried being normal once, didn't take....I think it was a Tuesday.
Reply:I remember thoseSent from my VS980 4G using TapatalkLincoln Power Arc 4000 Thermal Arc Fabricator 252 iThermal arc 186Thermal Arc 26 tigTweeko 200 amp spool gunHobart AirForce 400WP-17V-12R
Reply:We used to use tungsten to sharpen our knives when things got slow at work. TIG cups work for that, too.
Reply:I clean my teeth with it.......zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I think some welders use tungsten for the spark gap points.
Reply:I'll second what Timmy said about knife sharing works great to put the fine edge back on.Ranger 250 thick stuffHobart Handler 140 not thick stuffthe pane and oxy setup
Reply:Originally Posted by ManoKai...snip....  Robert Heinlein's sci-fi classic, The Moon is a Harsh Mistress, is an awesome read and variation on this theme.
Reply:Originally Posted by zapsterI clean my teeth with it.......zap!Originally Posted by mike837goBut the rebels only dropped rocks down the well and let 'em splash...
Reply:Originally Posted by asdfAs I recall, at one point in the story they had to stop targetting Cheyenne Mountain because it was no longer there.
Reply:^ Mike rocked indead.  "Discovery is to see what everybody else has seen, and to think what nobody else has thought" - Albert Szent-Gyorgyi
Reply:Originally Posted by TimmyTIGWe used to use tungsten to sharpen our knives when things got slow at work. TIG cups work for that, too.
Reply:Actually.  Boyscouts pinecar derby.  Needed to add some weight.Con Fuse!Miller Dynasty 350Millermatic 350P-Spoolmatic 30AMiller Multimatic 200Hypertherm PowerMax 1000G3Miller Maxstar 200DX
Reply:I put a sharpened tungsten into a pin vise and use it as a scribe...Rich
GMT+8, 2025-12-31 20:04 , Processed in 0.120634 second(s), 18 queries .
