my arc looks terrible on my tig welder
发表于 2021-8-31 22:29:24 | 显示全部楼层 |阅读模式
So I just started tig welding and my looks is completely crazy it's like a flame thrower I've tried adjusting everything. I don't know if it's my sheilding gas I have straight argon but every time I hit the trigger I hear the gas flow inside my machine I Dont know if that's normal since it's my first time using any sheilding gas. I have a ahp alpha tig 200x
Reply:It sounds like a gas issue, but tell us what you are trying to weld, machine settings, tungsten type size etc.   Post a pic of your machine settings etc and any attempted weldsAlso make sure it set to TIG not SMAWLast edited by soutthpaw; 09-06-2015 at 11:44 AM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:Originally Posted by soutthpawIt sounds like a gas issue, but tell us what you are trying to weld, machine settings, tungsten type size etc.   Post a pic of your machine settings etc and any attempted weldsAlso make sure it set to TIG not SMAW
Reply:Sounds like the argon hose is off or has a hole in it.is argon coming out of the torch?www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Here are some pics Attached Images
Reply:And yes I do hear some come out of the hose. Very quietly I have to turn it all the way up to hear it good
Reply:I sent you a PMwww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:Looks like George is on it.  You are definitely not getting gasAlso put it on 2T when using pedal.Set AC balance between 20-35%  and post flow to 5sLast edited by soutthpaw; 09-06-2015 at 01:34 PM.Tiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:So after talking to the mechanic George It looks like we got it sorted out my tungsten had been contaminated and my post flow was way to low my welds look cleaner now. They are pretty or perfect but a lot better now thanks for the help Attached Images
Reply:Originally Posted by CesarpalSo after talking to the mechanic George It looks like we got it sorted out my tungsten had been contaminated and my post flow was way to low my welds look cleaner now. They are pretty or perfect but a lot better now thanks for the help
Reply:I'm at 100 amp with 1/8inch aluminum. And yeah the back of the aluminum has the welds popping out alot
Reply:As someone being new to tig it will take some time to get thing to go the way you want. Like I said practice on steel as it is easier to learn on then aluminum.www.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
Reply:I found it easier to learn on Aluminum.  Originally Posted by mechanic416As someone being new to tig it will take some time to get thing to go the way you want. Like I said practice on steel as it is easier to learn on then aluminum.
Reply:These are how my welds are going so far? Any tips? I'm having trouble when I push the torch
Reply:Originally Posted by CesarpalThese are how my welds are going so far? Any tips? I'm having trouble when I push the torch
Reply:For 1/8 flat weld like that start it at 150 amps for the first inch or so then back off a little or start speeding up then post the pic back up. Too cold in post # 14
Reply:Were they all to cold?
Reply:Originally Posted by CesarpalWere they all to cold?
Reply:Ok ill work on that
GMT+8, 2025-12-31 18:24 , Processed in 0.101544 second(s), 18 queries .
